Does ABS Replace Braking Skill?
Both motors in this video are 2012, Harley-Davidson® Road King® Police (FLHRP) models. Both motors are equipped with ABS. Both are traveling at 40 MPH, and both begin braking at the same point. I'm riding the near motor, and stop using “threshold combination braking” (the maximum amount of braking, using both the front and rear brakes, before either a locked wheel or ABS activation), the rider on the far motor; one of the top police motor instructors in the world, deliberately engages the ABS, rather than using proper braking technique. As you can see, the properly braked motorcycle stops in excess of 20 feet more quickly than the motorcycle that is stopped using the ABS as a braking tool.
ABS is not a tool to stop the motorcycle (or any vehicle). ABS has only one function: to prevent locked wheel skids while braking. It does this by releasing and reapplying the brakes several times a second. As should be clear, this has the effect of lengthening braking distance, since the brakes are being released momentarily.
So, it is very important for riders to understand that proper brake application will stop a motorcycle faster, since it uses all the efficiency of the brakes. It is also important to understand that the fact that a motorcycle is equipped with ABS does not – by itself – increase the stopping distance. Unless either poor braking, or a surface change causes ABS activation, an ABS equipped motorcycle will function exactly like one without ABS. The value of ABS is that it allows a vehicle to stop safely, when either of these issues occurs. On a motor without ABS, those things would cause a locked wheel skid, which not only increases stopping distance, but results in instability often leading to a crash.
ABS is a tremendous safety feature, and if it’s available, on any vehicle you are considering you should insist that your vehicle be equipped with it. However, a motorcyclist should no more use ABS regularly than the driver of a car should frequently use the air bags.
If your interested in more on ABS, and how to use it properly, email me at:
motorlessons@hotmail.com
I'll send you back my (free) booklet.
Harris
Denver, CO
www.youtube.com/conedown
As far as needing this type of system...I can count on finger when I REALLY needed it. I got lucky, but it would have saved me several gray hairs! Maybe??????
Harris
Denver, CO
The point of this video is that no motorcycle will stop as quickly in full ABS as one being braked properly. This is not a failure of ABS, this is the reason riders should not rely on ABS as a way to stop.
Any one who would choose not to have ABS when it is available is making a life-threatening mistake, since ABS allows control when poor braking skills or poor braking surface would have resulted in a locked wheel. If an error occurs during proper braking, and ABS activates, a safe stop is still the result. Correctly dealing with a locked wheel - that occurs without ABS - requires skill that very few riders have developed.
If a rider feels his ABS activate, he should immediately understand he has made an error either in braking application or surface appraisal.
Take any ABS event as a time to learn to brake better. Analyze what happened to cause ABS to activate. It's much easier to do this after an ABS event than it is to do it after a locked wheel skid, since those are typically the precursor to a wreck.
Harris
Denver, CO
It reminds me of an air bag in a cage. It will probably never be deployed but if it does, it may have just saved your life.
I love a safety feature that you never know it's there until you need it.
