Exhausr Install
Old Aug 15, 2012 | 02:41 PM
tjcaron's Avatar
tjcaron
Default Exhausr Install
I ordered some Rush headers, exhaust, and a SE air cleaner from the dealer. I know I can do the air cleaner no problem but I've never done the exhaust before. The dealer wants to charge about 3 1/2 hours worth of labor not counting the money for the download.
I just got off the phone with Brian at FuelMoto and they have the Rush Maps and can send me a PC V for $299 with the map installed.
I just think it would be much cheaper to do the work myself. So, how difficult is it to do an install of headers and mufflers?
Old Aug 15, 2012 | 02:49 PM
Mike_M's Avatar
Mike_M
Do you have some basic hand tools? Sockets, screwdrivers, and a torque wrench?
Do you know what the different tools are for? (socket wrenches are NOT hammers, no matter what my wife thinks)
If so, you can do the install easily.
You may have to get a crowfoot wrench or universal for your socket in order to reach the exhaust manifold nuts, but that's the hardest part of the whole install. Well, that and ensuring that you don't mistake ft/lbs for in/lbs on the torque.
Old Aug 15, 2012 | 03:23 PM
tjcaron's Avatar
tjcaron
Guess it would give me a good reason to go buy a torque wrench and a service manual.
Old Aug 15, 2012 | 03:45 PM
BlackPearl#1's Avatar
BlackPearl#1
Like Mike says, basic tools and knowledge will get ya thru it. Ya might, and i repeat, might want to get a set of exhaust gaskets if the new head pipe doesn't come with them. Youtube will be your friend on this one for sure. And last thing is ANYTHING the boys at FM do, is done the right way, no B/S over there at all!!! Good luck with project.
Kris
Old Aug 15, 2012 | 06:07 PM
Airborne350G's Avatar
Airborne350G
And put your exhaust gaskets in the freezer to shrink them. It will make it easier to install. Learned that when I used to work on helicopters.
Old Aug 15, 2012 | 06:22 PM
TUCCI's Avatar
TUCCI
Kris
Not the flat gaskets but the tapered one's.......
Old Aug 15, 2012 | 08:49 PM
sportyrider1's Avatar
sportyrider1
IMHO the exhausts is easier than the air cleaner. you will need both a inch/lb (1/4 inch) and a ft/lb (1/2 inch) torque wrenches but for a lot of HD wrenching you will need them anyway (probably fixing to get flamed but the harbor freight torque wrenches are good enough for the home users http://www.harborfreight.com/catalog...=Torque+Wrench)
also buy a inexpensive 3/16 Allen wrench that you can grind down it will make removing the old air box easier.
Old Aug 15, 2012 | 08:53 PM
saschagast's Avatar
saschagast
i installed Rinehart true duals, air cleaner and power vision in about 2 hours and my SG is my first Harley. So you'll be fine, it's easy
decencyxdefied
May 18, 2019 07:48 PM
moonshined
May 10, 2011 06:03 PM
stbobau
Nov 2, 2010 09:34 AM
Mobscene
May 24, 2008 12:49 PM
Jman67
Jun 7, 2007 11:01 AM
