are Detach Setup Question
Old Jan 20, 2007 | 08:18 PM
Badbagger's Avatar
Badbagger
Default are Detach Setup Question
On my 06 Road Glide I am going to add either a chopped or full tour pak which won't stay on all the time so I've got the quick detach kit coming as well. Still deciding on which size TP. I looked into also getting a quick detach backrest for the Mrs when we are jest scooting around. The hardware for the backrest and tour pak are two different stocknumbers on the Moco site. Am I locked into one or the other or will they be interchangeable?
53804-6
Two-Up Tour-PakĀ® or Two-Up Luggage Rack
Fits '97-later Touring models (except FLHTC/I and FLHTCUI).
53803-06
Sissy Bar Upright or Solo Tour-PakĀ® Rack
Fits '94-later Touring models (except FLHTC/I and FLHTCUI). '94-'96 models require separate purchase of Hardware Kit P/N 53660-05 and 53658-05
Thanks!
[sm=feedback.gif]
Old Jan 20, 2007 | 08:30 PM
04harleyboy's Avatar
04harleyboy
Default RE: are Detach Setup Question
You need to get them both to do what your talking about. One for the backrest, the other for the our pak (unless you set up the tour pak for solo riding) then thats a whole different story [:@]
Old Jan 20, 2007 | 09:31 PM
Tech2's Avatar
Tech2
ORIGINAL: 04harleyboy
Does the solo tourpack set-up use the same docking points as the backrest?
Old Jan 20, 2007 | 10:19 PM
jward2331's Avatar
jward2331
Tech2
The answer would be yes to your question. There are two different docking systems. Sissy bar and solo tour pack uses one and tour pack for two up is another.
Old Jan 21, 2007 | 09:03 AM
Badbagger's Avatar
Badbagger
Thanks!
Old Jan 21, 2007 | 02:25 PM
Tech2's Avatar
Tech2
Thanks.
I knew that there were different sets of hardware for the backrest and the two-up tourpack. I installed the detatchable backrest and docking hardware on my FLHXI, so I suppose the solo tourpack rack will attatch to that. And if I want the two-up detatchable tourpack I'll need to install the other docking hardware. Right?
Lone Dawg
Jun 22, 2016 09:16 AM
tlar1540
Sep 30, 2012 02:03 PM
Throwback
Jun 9, 2011 06:51 PM
obwhan
Sep 27, 2010 11:27 AM
ballbreaker69
Jun 9, 2010 09:21 PM
