Easy way to remove cat?
Old Aug 23, 2012 | 02:48 AM
frozensoul's Avatar
frozensoul
Default Easy way to remove cat?
Anyone ever take the heatshield off, cover every thing up good on bike and cut a piece out like a panel to remove the cat and weld the panel back in to keep from taking the exauhst off?
Old Aug 23, 2012 | 04:15 AM
Mark5's Avatar
Mark5
Read the "decatting debate" thread. Another way to do it other than cutting it apart.
Old Aug 23, 2012 | 06:47 AM
dawg's Avatar
dawg
Shoot it!
Old Aug 23, 2012 | 08:45 AM
TUCCI's Avatar
TUCCI
I would pull it off the heads and away from the bike. You need to grind, push, tug and there will be sparks with metal shavings all over the place. The first time a hot metal shaving gets under all the good intentions you will kick yourself for trying to cut corners. Do it right, once you've had the header off once it will be cake if you need to remove it again. Resist the temptation to getting lazy.
Old Aug 23, 2012 | 01:05 PM
Casper's Avatar
Casper
Easiest way is to remove the header and send it to FullSac and have them turn it into a sport pipe....
I removed mine, cut the panel and TG welded the panel back....easy peasy...
Old Aug 23, 2012 | 02:19 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I went to VH power duals, it put more zip in my doo dah!
txdrifter8705
General Topics/Tech Tips
Jul 21, 2017 07:16 AM
MNrider
Aug 7, 2008 10:15 AM
bugman69
May 17, 2007 07:50 AM
jjr
Oct 23, 2006 03:34 PM
bob53
20
Apr 5, 2006 04:07 PM
