How is this possible?
Old Aug 25, 2012 | 08:47 PM
BigGelvis's Avatar
BigGelvis
Default How is this possible?
How is this possible? This guy has after market radio but on the top of the dash, there is the HK radio?? Does the HK radio have a removable face that lets you somehow stash the HK unit in the fairing and mount the face like it seems this guy did?
http://www.youtube.com/watch?v=lNIbUb0zbS4
Old Aug 25, 2012 | 08:54 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Can't answer your question.
I bet the cruise works on it, 'cause he would need one free hand to do the record scratchin'...
Old Aug 25, 2012 | 09:00 PM
RoadLord's Avatar
RoadLord
The music is pretty GAY!
Old Aug 25, 2012 | 09:04 PM
Timmy B's Avatar
Timmy B
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
I agree!
Old Aug 25, 2012 | 09:14 PM
BigGelvis's Avatar
BigGelvis
I AGREE, music sucks!
But what I want to know is how and why the HK radio is sitting on the dash up there?
I am installing an after market radio but I also have the HD security system and CB. If there is a way to retain those and mount it up there like he did, I would like to find out how that is possible?
I don't use the CB or the intercom but if my key fob ever dies, you have to enter a code VIA the HK head unit or call a toy truck to the nearest dealer.
With an after market radio, I would be calling a tow truck unless I had what it looks like this guy has, a relocated HK radio face on the dash.
Old Aug 25, 2012 | 09:19 PM
Airborne350G's Avatar
Airborne350G
Looks like they wired in the HK faceplate. Not sure where the rest of the radio is located. Must be somewhere so he can still use intercom and CB.
Old Aug 25, 2012 | 09:41 PM
Nute's Avatar
Nute
Not really sure what your radio has to do with your security system. You use the left and right signal switches to input the numeric code which shows up in your odometer.
Entering the PIN to Disarm HFSM (Example: 3-1-3-1-3)
NO. ACTION WAIT FOR CONFIRMATION NOTES
1 Set engine stop switch to OFF.
2 Turn ignition switch to IGNITION.
Security lamp blinks at fast rate and "0- - System is ready for PIN entry.
- - " is displayed in the odometer. The first
digit flashes.
Hold both turn switches in until confirmation.
3 Enter first digit of code (3) by pressing left
turn switch three times.
4 The first digit will be displayed and the next Serves as enter key.
dash will flash in the odometer.
5 Press right turn switch once.
Enter second digit of code (1) by pressing
left turn switch once.
6 The first two digits are displayed and the Serves as enter key.
next dash flashes in the odometer.
7 Press right turn switch once.
Enter third digit of code (3) by pressing
left turn switch three times.
8 The first three digits are displayed and the Serves as enter key.
9 Press right turn switch once.
Enter fourth digit of code (1) by pressing
left turn switch 1 time.
10 The first four digits are displayed and the Serves as enter key.
11 Press right turn switch once.
Enter fifth digit of code (3) by pressing left
12 Security lamp stops blinking and the odo- System is disarmed.
meter displays miles.
13 Press right turn switch once.
* This must be done within two seconds of turning the ignition switch to IGNITION. If system issues a warning before the security
system flashes at a fast rate, then cycle ignition switch OFF until security key icon flashes at 2.5 second rate before re-attempting
PIN entry.
HOME
3-8
When you rec'd the bike there should of been a security code already installed. If you don't know what it is you should read your owner's manual and find out what it is while your FOB is still working. (You need to have a functioning FOB near your bike to find out code.) It would also be a good idea to change the code to one you can remember as one day you may have to use it to start your bike.
Old Aug 25, 2012 | 10:09 PM
BigGelvis's Avatar
BigGelvis
digit flashes.
PIN entry.
HOME
3-8
Ahhhh............Good to know, I thought it was in the HK radio that I would have to input that data!
Old Aug 25, 2012 | 10:22 PM
In2It's Avatar
In2It
All that info is in your owners Manuel
Old Aug 26, 2012 | 01:38 AM
RoadLord's Avatar
RoadLord
*scribble scribble scribble*
Ahh dammit!
