Can Monster Rounds be made Louder?
Old Aug 31, 2012 | 10:09 AM
Tn.Heritage's Avatar
Tn.Heritage
Question Can Monster Rounds be made Louder?
Love the rumble but not loud enough for my taste. I really hate to take a beating on these things so I asked V&H's if they have a louder baffle.
Has anyone done this already?
Old Aug 31, 2012 | 11:19 AM
DannyZ71's Avatar
DannyZ71
I can't even see a way to remove the current baffles. Maybe I just haven't dug into them enough yet. Does the end cap hold them in?
Also, if yours are new, give them about 1,000 miles then see if you still want to change. I got mine used, but the guy said he only had 300 miles on them. His complaint was they weren't loud enough also.
Since getting them, they have gotten louder. So much so that I am kind of disappointed in them. I really wanted the rumble, but not the loudness. Now I have both. Still not as loud as wide open pipes, but quite a bit louder than when I first got them.
Old Aug 31, 2012 | 12:08 PM
mgmmgm's Avatar
mgmmgm
You can pull the baffle out and remove the fiberglass wrap and reinstall the baffle core.
Yes they are louder that way.
Check the threads as I posted about monster rounds.
Basically undo the two Allen screws on the bottom side of the end caps
The end caps have those grooved semi circle notches in the, which I stuck an Allen wrench in the slot so that the Allen was locked in going across the baffle end cap.
I have chronic tendinitis in my elbows, so I can't grip well to turn the end caps back and forth clockwise/counter clockwise to get 'em loosened up.
I used a crescent wrench on the Allen stuck crossways in the end cap to get some leverage to bust it loose.
Once I had it loosened some, I fired up the bike and revved it up a bit so the exhaust pulses would help push it out.
When I was able to extract the baffle an inch or so, I used tapped with a hammer on a small wood dowel to on the backside of the end cap ring, to drive it out while also using hands to twist it out as well and some engine revs again.
It took me all of 30 minutes to get both cores extracted, and reinstalled.
Note: tap gentlely. I posted some pictures on YouTube if you type in 2011 Roadking classic
http://m.youtube.com/watch?feature=p...r/markroadking
Hope this helps.
Old Aug 31, 2012 | 12:16 PM
mgmmgm's Avatar
mgmmgm
http://m.youtube.com/watch?feature=m...r/markroadking
Check this out
Old Aug 31, 2012 | 08:27 PM
asahi1234's Avatar
asahi1234
I have the Supper Trapp Kerker pipes and I wanted them louder. So I asked Supper trapp could I just remove the packing material. They said I could but it would turn my pipes blue. So I didn't. Has anybody remove the packing material and there pipes didn't turn blue?
Old Sep 1, 2012 | 06:37 AM
Tn.Heritage
Wll I did pull the baffles, no problem at all but man those things are wrapped tight with packing. I just slid them back in and pulled them off and back to the dealer. I traded for some RC Compents, Whoa, you talk about a difference. These babies are awesome. Got a bigblock sound to them in a sort of way and loud. Going on my first ride today with them and I'll report back.
06SGWA
Oct 9, 2014 09:36 AM
Lawdawg
Sep 19, 2012 02:55 PM
mgmmgm
Sep 9, 2012 04:08 PM
rysess20
May 15, 2008 05:47 PM
TexasBowhunter
Oct 18, 2006 09:52 PM
