Re-map?
Old Aug 31, 2012 | 04:36 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by HDRoadking_nc
...Now what is the real story?...
The FL-XIED-10 fools the ECM...[/B]
I just can't understand why the ECM has to be "fooled" into thinking something is going on when it's not.
Your quoted passage clearly states..."The engine is not 'technically' lean, nor will it go lean when you make exhaust and air cleaner upgrades."
Why not just accurately give the engine (through the ECM and all it's various tables and sensors) what it needs (or the rider wants it to have) to provide the results one is seeking?
IMHO, to "fool" the system and just arbitrarily dump in more fuel seems a bit amateurish.
Old Aug 31, 2012 | 04:57 PM
TUCCI's Avatar
TUCCI
Originally Posted by Baditude75
Ok thanks. Guess i was hoping to save the $350 but thats gonna be cheaper than a meltdown.
$299 with loaded map if you go with Fuel Moto....call Jamie and tell him your setup.
Old Aug 31, 2012 | 05:13 PM
Jswerve's Avatar
Jswerve
I got quoted $499 for the PV from fuelmoto??
Old Aug 31, 2012 | 05:17 PM
Keithhu's Avatar
Keithhu
I think he's talking about a Power Commander, not a Power Vision, but I could be wrong.
Old Aug 31, 2012 | 05:19 PM
Baditude75's Avatar
Baditude75
5th Gear
Thanks for all the info guys. Sounds like even though i may not HAVE to remap its probably a good idea to do it so it runs better.
Old Aug 31, 2012 | 05:23 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Because it costs 250% more to get about a 10% better result. (and that 10% is rarely used or felt by most riders)
The XiED family of Products do not arbitraily dump in more fuel. They work in conjuction with the ECM to put the AFR at a preferred 13.8:1 - 14.1:1 instead of the EPA performance choking 14.6:1 AFR.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Aug 31, 2012 | 05:25 PM
Jswerve's Avatar
Jswerve
Hmmm what's the major difference between those?
Old Aug 31, 2012 | 05:32 PM
Keithhu's Avatar
Keithhu
One is a piggy back system, one is a flash tuner.
Old Sep 1, 2012 | 12:19 AM
luisan's Avatar
luisan
Originally Posted by DK Custom
The less expensive way to go is $100 for some XiED's
Click HERE for all the details
You do not have to do it. Your ECM will compensate for just the air cleaner...it will keep it at the EPA mandated 14.6:1 which will not damage your engine, but it is less than a satisfying riding experience.
By installing the XiED's you will get a much smoother running engine, and it will not run as hot. Surging and hesitation that is common in the stock EPA tune will be gone.
Is there an XiED for the '06 EGs?
Old Sep 1, 2012 | 12:32 AM
mgmmgm's Avatar
mgmmgm
Default Check
Check out Fuelmoto website, good info
