help question
Old Sep 11, 2012 | 11:25 PM
daveg2007's Avatar
daveg2007
Stage II
Unhappy help question
i have a 2007 dresser i have a weard sound coming from the air box when i give it gas it sounds like an air comp and in the front cyclinder thair is rocker noise that comes and goes the sound changes with temp i do have some mods done stage 1, s&s lifters cams adj push rods thanks dave..
Old Sep 11, 2012 | 11:31 PM
jjnoble's Avatar
jjnoble
I'm not exactly sure what all you are saying there, but sometimes with some air cleaners you can hear air going through it and other engine noises coming from it. With a stage 1 you have turned it into an open port and you are sitting right on top of it so you will hear things you didn't with the stock.
Old Sep 11, 2012 | 11:33 PM
soft 02's Avatar
soft 02
Dave if you listen carefully you can here many normal things. The sucking of air into the air cleaner, the counter balancers swishing, the buzz of the injectors, the valves slapping closed under acceleration, the ticking of the rocker arms. All these things are normal. Now if you here a new and different noise try to pay attention under what condition it occurs, with road speed, clutch pulled in, acceleration, deceleration. Try to listen for the different things going on. Remember you are sitting on and engine. You might have a pushrod thats a tad out of adjustment or coming loose.
papadop88
May 22, 2014 09:28 PM
1sweetglide08
Aug 7, 2012 12:20 AM
Glock Enthusiast
Jul 27, 2011 08:18 PM
ubreal
Exhaust System Topics
Sep 13, 2007 11:53 PM
smithk
Sep 24, 2006 11:02 PM
