Radio & CB woes
Old Sep 17, 2012 | 10:21 PM
aesop081's Avatar
aesop081
4th Gear
Default Radio & CB woes
Hi all,
I have a 91 Ultra Classic that is still going strong mechanically, electrically it needs some TLC. I want to replace the non working original sound system and CB. Any suggestions on how best to accomplish this? When I stored it last winter, after reconnecting the battery this spring the radio has stopped working.
Any suggestions on replacements options and vendors?
Ken
Old Sep 17, 2012 | 11:13 PM
D1gger's Avatar
D1gger
First I would suggest you check the radio's fuses and ground, as well as all the connections in the fairing. You might get lucky and find a blown fuse or loose plug. If that doesn't fix it up and you still want to replace it, good luck in your search. You will most likely end up going one of a couple different paths.
You might be able to find a working stock radio to replace yours with, this would keep your speed-sensitive volume and handlebar controls. You might be able to talk biketronics into making one of their older handlebar control wiring kits to go with one of their aftermarket head units, but you'll lose the CB and the speed volume. This will be expensive, too, like around $500. Another option is to remove the enitre stock setup and replace it with aftermarket stuff, but again you'll lose the CB, handlebar controls and speed volume. Plus CD head units rarely work right on a harley, the CD's skip from the vibrations. Removable face-plate radios also end up developing problems down the road with dust, dirt and vibrations ruining the contacts on the face-plate, causing them to cut out.
HERE is a pretty good thread over in the Evo forum about radio upgrading in the older bikes. Check it out and read every post, there is a lot of good info in there.
Good luck and welcome to the forums!
Gone Blue
EVO
14
Mar 25, 2018 02:10 PM
Nightshift22
Audio Systems
Nov 7, 2012 06:59 AM
badazzpred
Mar 2, 2012 09:30 PM
Mikeeeeeeeeee
Sep 28, 2007 12:59 PM
SparkyRKM
Aug 12, 2007 12:10 AM
