motor break in procedure.
Old Sep 19, 2012 | 04:32 PM
louie c's Avatar
louie c
O.k.
Tks for all the feed back.
Ride safe all.......
Lou.
Old Sep 19, 2012 | 04:39 PM
Robert9999's Avatar
Robert9999
Originally Posted by KCFLHRC
Agreed, read your owners manual and follow it. These fancy break in procedures are just someone's theory. Probably the most important thing is to keep the RPM's up and don't lug the motor.
+1 lugging is the worst thing you can do to the motor new or broken in
Old Sep 19, 2012 | 06:11 PM
chainsaw123's Avatar
chainsaw123
just ride it like it is going to be ridden the rest of its life. If you are a slow / lugger rider then do that. If you are like me, fast off the line, run through all gears, cruise at 70-80mph then ride it like that from new. just my 2 pennies worth......
Old Sep 19, 2012 | 07:31 PM
MNPGRider's Avatar
MNPGRider
I think the article you read applied to an engine rebuild. New bikes are run in at the factory, and the rings should already be seated.
If you watch the "incredible factory" shows on the History channel, you will see one on the Harley factory, with techs running new bikes on the dyno. If they don't perform to specs, they are rejected.
Old Sep 19, 2012 | 07:39 PM
FL-kruzen's Avatar
FL-kruzen
ok...how come no one ever discusses break on cars? I think you should just ride and don't redline it or luge the engine, but please, I think folks go batty over this topic
Old Sep 19, 2012 | 07:44 PM
TORQUEY's Avatar
TORQUEY
No, static engine runs do not seat the rings, even on a dyno. It needs the "load" of actual acceleration and deceleration for this to work. This works on engine rebuilds, but is primarily intended for new break ins for ALL 4 stroke motors, bikes, cars, etc. Please check this link:
http://www.mototuneusa.com/break_in_secrets.htm
Old Sep 19, 2012 | 08:23 PM
MNPGRider's Avatar
MNPGRider
On the very link that you posted (which I am familiar with), you will read about the three ways to break in an engine.
The first one is on a dyno. Up here in the frozen north, many rebuilds are done in the middle of winter and the engine is broke in in a warm shop on a dyno. As far as load, check out the weight of the spinning drum in a dyno.
Rickr01
Milwaukee Eight (M8)
May 10, 2018 05:54 PM
markkoby
Apr 9, 2012 02:59 PM
HoggyMtnBreakdown
Jun 27, 2011 02:32 PM
SmittyFXDL
May 27, 2010 11:39 PM
1931jamesw
May 5, 2009 11:08 PM
