Squealing from rear end
Old Sep 19, 2012 | 09:58 PM
Troubleman's Avatar
Troubleman
Originally Posted by big gus
Well I can see these fourms are a waste of my F#@^ing Time.Thanks for nothing.
Easy big guy. We're just having a little of fun. If you've been lurking on here for any time at all, you'd know that with an open end question like that, guys are gonna have a little fun and someone will eventually get serious. It's nothing personal.
Old Sep 20, 2012 | 05:46 AM
EasternSP's Avatar
EasternSP
Originally Posted by drukanfu
Oh kiss my *** ! The op writes in with some lame question about squealing from the rear end, I think most figured he was just being funny. Somebody thats got a bike since 2001 and presumably longer should know what basics to check for before going on a forum and asking people like you, that is people with no sense of humor and no real knowledge of bikes other than what you read in 8th grade shop class.
Go help some ole lady across the street, will ya !!
Welll, yeah. He's got 15 posts and all of them are dealing with a noise coming from the rear of his bike. A really jokster posting here, right drukanfu?
Old Sep 20, 2012 | 01:18 PM
big gus's Avatar
big gus
Hey drunkanfu-ck I have checked all the basics from belt tension,aligment,worn belt.Did the belt soap test, cracked motor mounts,Rubber bushings,and exhaust brackets,exhaust tension,Swingarm bearing,and a few other things that you wouldn't understand.Rather then take it to the shop I try workin on my own Ride.I've been riding Harley's while you were still shittin Yellow brudder.But even the most experienced Riders get jammed once in a while.That's why these fourms were put in place.
Old Sep 20, 2012 | 02:18 PM
RoadGlidinFreak's Avatar
RoadGlidinFreak
Had something like that happen on my old bike the first time I adjusted the belt..
I know you already said you've checked the belt tension... so probably doesn't actually apply to your situation ....
but in my situation... I adjusted the belt to the specs in the book..... when it got hot it would kind of whine... squeal... high pitched maw... what ever you want to call it. Mainly when I let off.... I had to run the belt with the Ultra Classic tension instead of the Street Glide tension......
Old Sep 20, 2012 | 06:35 PM
Cigarmessenger's Avatar
Cigarmessenger
My apologies for stepping on a nerve! I hope you find a solution to your problem
Old Sep 20, 2012 | 06:41 PM
btsom's Avatar
btsom
After that list of stuff you've already checked, have you had a good look at the rear brake?
Old Sep 20, 2012 | 07:51 PM
69cj's Avatar
69cj
I would be taking a close look at the wheel bearings. I had one going out that I couldn't hear unless riding next to the K-rails on the highway. Don't rule the simple things out. That's usually what bites us in the ***. Don't mind the sarcasm. That's what makes us diff. from cagers.
Old Sep 21, 2012 | 06:31 AM
big gus's Avatar
big gus
Thanks Guys for the feedback.Leaning towards the wheel bearing myself now.Nothing ****s up my head like a problem I can't fix. No disrespect intended.Ridin 'em like ya stole 'em. L&R Big Gus
Old Jun 7, 2013 | 01:00 PM
big gus's Avatar
big gus
Well it was indeed the Wheel bearings.Both were shot.Problem solved.Thanks for the input.ML&R Big Gus
Old Jun 7, 2013 | 02:24 PM
jus2anoyu's Avatar
jus2anoyu
See there?! These forums are good for something. I know how frustrating it is when you have a problem and just need some straight up advice, and you get jokes. There are other places on the webz that have far less drama, and maintain a much more serious atmosphere. But, they are not nearly as fun. Glad you found the problem. Now go ride!
