The dreaded 103 noisy engine
Old Sep 28, 2012 | 04:05 PM
  #51
ddm502001's Avatar
ddm502001
Our new 103 had quite a lot of upper noise as we took it out for a long ride(2800miles), as soon as the 1K service was done it quieted down some, still a bit noisier than our old 88 but not as bad as have heard of here. We have a FLTRU, 2012, it has full lowers and stock exhaust including the CAT so I hear the engine more than the old RK FLHR, 2003 even as it had lowers but Monster Ovals and aftermarket exhaust with NO cat.
Have been around quite a few rides 2008 and newer, most had some engine noise and as noisy as our 103.
Old Sep 28, 2012 | 04:07 PM
  #52
1sicmofo's Avatar
1sicmofo
I add 2oz marvel mystery oil to a full tank, lubes the top end, cleans as it lubes.
Trick i learned from a bike racer as race fuel has no lube in it and is highly corrosive.
Use in all my bikes and my truck,seems to quiet things down a little.
Old Sep 28, 2012 | 04:11 PM
  #53
mgmmgm's Avatar
mgmmgm
Default Clowns
Originally Posted by Retrop
You got the "Harley Kiss". First on the lips and then on the ***. If those clowns in the service area suspect that you are not too mechanically inclined they are liable to tell you anything to appease you and send you on your way.
LOL clowns.......
And one hell of an expensive circus, with a labor rate @ $90.00 an hour!
Old Sep 28, 2012 | 04:14 PM
  #54
glcash's Avatar
glcash
Originally Posted by mgmmgm
LOL clowns.......
Lol that's funny. It's a shame we customers can't depend on our own dealer!
Old Sep 28, 2012 | 04:36 PM
  #55
kwo51's Avatar
kwo51
We used to run marvel myster oil through the carb to get carbon out. Back in grease monkey days. Now all the oils ,gas, grease and punta are caner causing..
Old Sep 28, 2012 | 07:03 PM
  #56
kq2dc7's Avatar
kq2dc7
My dealer changed my ECM because of the pinging on my 12 RK. They have changed a few others as well. The map is definitely different it seems to have boosted the tach limiter. It definitely got rid of the noise.
Old Sep 29, 2012 | 03:38 AM
  #57
RangeRat's Avatar
RangeRat
Sounds like they did a "Stage 1" flash. From what I've heard, that includes +10% fuel to the AFR and extends rev-limiter to 6500 RPM. The fuel increase helps with ping but, for a stock engine with stock cams, the rev extension is probably worthless. I suspect you're better off shifting at a max of 5500 anyway since 6500 is pretty far beyond the sweet part of the stock torque/power curve (and not really suitable with the stock 103).
Old Sep 29, 2012 | 03:56 AM
  #58
Shredding rubber's Avatar
Shredding rubber
Marvel mystery oil added to oil will dissolve sludge slowly so I'm not sure why it's mentioned here unless the person is suggesting adding it to the fuel which isn't a good idea since it contains phosphorus which is the whole reason the API told oil companies to change their formulations because phosphorus poisons catalytic converters.
I do however use a home brew fuel intector cleaner/upper cylinder lube/octane enhancer/mileage improver that contains the tc-w3 2 stroke oil. Tc-w3 2 stroke oil burn cleany with no ash so when used in moderation doesn't foul plugs nor interferes with o2 function. And since ethanol fuel pumps do benefit from the light oil going through it. It also contains detergents which keep the fuel system clean.
There is a huge write up on it's use in a chevy forum,ls-1 owners forum or something.
1 ounce per 5 gallons seems to be the general consensus to achieve a positive result.
My home brew has worked for me in every machine I own. From generators to compressors to vehicles and bikes. Never a single fuel issue and everything gets better than advertised fuel consumption.
K. OP. As far as the noisy engine goes try using an automotive oil if you aren't already and get a straight grade,as thick as possible from either royal purple,red-line,motul or even the straight 60 from Amsoil.
Perhaps a conventional will also lessen the sound. Thicker will insulate the insides better and lessen the noise.
Or run a thin convetional and blow it up so harley has to fix it before warantee expires.
Old Sep 29, 2012 | 06:53 AM
  #59
Wild Card's Avatar
Wild Card
My flhr makeno more noise than my 01' wideglide, and every one knows that was the best motor built. Natirally when I went to 95" and gear drive cams there was no valve noise.
I had pinging when I first got it in june, mainly in the high gear near lugging condition. That pinging went by the wayside with pipes, a/c and download. Will be getting a tuner this winter. Most likely coulda been cured by download and no lug condition
I dont see how or why this motor would be different than any twin cam otherthan bore and stroke. Other than the obviouse crank changes which is industry wide. I/e a 99' ford 7.3l psd had forged rods, my 01 has powder machine rods (pmr) and after 500 hp theae rods will let go.
Some issues with the moco are legit, but the internet plus the fact that most riders now have no mechanical inteligence, not trying to hurt anyones feelings but sorry not everyone is mechanic thus do not understand.
Old Sep 29, 2012 | 06:57 AM
  #60
Timmy B's Avatar
Timmy B
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
I've got a 2010 FLHTK and I have never had an issue, granted I have had some major work done to it, but the bike runs great!
