TW222 cams in a month
Old Sep 22, 2012 | 11:13 PM
mgmmgm's Avatar
mgmmgm
Thumbs up TW222 cams in a month
Pulled the trigger on the TW222 cams.
Will be getting PowerVision with handlebar mount as well.
Will be getting the TW 222 cams installed the first week of November, bummer that it is late in the year, my Indy is booked out all the way until then.
While talking to my Indy about the project, he showed me the Zippers Performance- Red Shift® Dual Piston Cam Chain Tensioners, which will go in the work he is doing with the cam install package, and he will be putting in Feuling lifters.
I ran Feuling lifters in my last build with no issues. Also, he said he'd put a shim under the oil spring to give the pressure a nudge, mostly so oil pressure at idle will not be so low.
Also, I will be using Fuelmoto cam kit that includes the Torrington cam bearings, which is a plus.
I will post a video after all is done, if it is not to freaking cold to do so.
Old Sep 22, 2012 | 11:39 PM
Keithhu's Avatar
Keithhu
Nice.
Whats wrong with the existing chain tensioners?
Old Sep 23, 2012 | 02:27 PM
mgmmgm's Avatar
mgmmgm
Thumbs up Cam chain tensioners
Originally Posted by Keithhu
Nice.
Check out zippers performance see new performance parts, cam chain tensioner.
My Indy does great work and recommended the zippers cam chain tensioners, the zippers web page describes benefits pretty well.
At any rate, a small bit of improving on what OEM could do..... I figure might as well while the job is being done.
Cheers,
Mark
EarlB
Engine Mechanical Topics
Aug 7, 2018 09:19 AM
streetking1
Jan 22, 2017 12:17 PM
Chief2505
Apr 2, 2016 01:23 AM
heavypic
May 16, 2011 08:31 AM
sliver
Exhaust System Topics
Jul 8, 2008 12:21 AM
