dropped bike and will not start
Old Sep 24, 2012 | 11:09 AM
silky1859's Avatar
silky1859
Thank you all...not stressing taking this in a good way...i am learning thru this process but dang it i want my baby to start...ha ha ha
Old Sep 24, 2012 | 11:13 AM
drukanfu's Avatar
drukanfu
I looked up P1510 it says Throttle actuator control limited performance. You might have just moved the Throttle position plastic tube in the end of the handle bars while trying to hold the bike up too.
Old Sep 24, 2012 | 08:16 PM
silky1859's Avatar
silky1859
Still does not want to start...someone stated a tilt switch...they say under the seat so tomorrow that is what i am doing...
Old Sep 24, 2012 | 08:17 PM
silky1859's Avatar
silky1859
the code is PO 151...that is what it show on odem when i do the diagnose
Old Sep 24, 2012 | 08:30 PM
MNPGRider's Avatar
MNPGRider
Isn't technology wonderful? In the good ol' days, if you dropped a bike, you stood there and watched it do spinners in the dirt.
Old Sep 24, 2012 | 08:40 PM
btsom's Avatar
btsom
Do you have a security fob? I believe you get the same symptoms from a dead fob battery. It would be quite the coincidence, but possible.
Old Sep 25, 2012 | 08:31 AM
silky1859's Avatar
silky1859
I do have a arlam system on bike but disarmed. So i took the bags, seat and side cover off. Since i had this bike i just rode it now for me to do this is exciting but still does not want to start. Do not know of the location of the tilt switch. does anyone know where it may be located? Someone stated under neath the seat but do not see it.
Old Sep 25, 2012 | 10:41 AM
silky1859's Avatar
silky1859
Well i finally took the battery out and putting it on a charger so hopefully taking it out will reset the bike...crossing fingers. if not will take to shop and have them reset the bank angle sensor
Old Sep 25, 2012 | 01:44 PM
Tampakingpin's Avatar
Tampakingpin
This seems like one of the better informative/problem solving threads. Nice work forum
Old Sep 25, 2012 | 01:53 PM
wtb3886's Avatar
wtb3886
Greetings silky1859
07 hd electra glide classic
to locate your model go here
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
to find your location of the tilt switch.
When you put your odometer into diag mode, did you see (PSSPE) P S SP E, if so was the P the only letter flashing?
We need to verify the PXXXX numbers after the P, what are they?
In order to reset back to normal all you have to do is once the press the reset button and you see (the end), press the reset button an hold until you see (Clear), at this point you have reset the trouble code back to normal, that is if no problem exist, if this is the case the you will not be able to reset until you have taken care of the problem 1st.
Let us know the numbers after the P then we can get your bike running.
