CVO Help
Old Sep 27, 2012 | 09:18 AM
Leveewalker's Avatar
Leveewalker
6th Gear
Default CVO Help
Bought my first ultra cvo 2012 model but can't find any info on how to remove the tour pack"quick detach" is there any help out there?
Old Sep 27, 2012 | 09:25 AM
Redbeard719's Avatar
Redbeard719
I don't believe the standard issue is quick detach...you'll need to puchase the 4 point docking hardware, and the TourPak mounting plate for the docking hardware. I'm not certain if there are additional parts required.
Old Sep 27, 2012 | 09:37 AM
KeeBee's Avatar
KeeBee
Normally you have to buy the over priced quick de-tatch kit even on the CVO's.
Old Sep 27, 2012 | 09:43 AM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
Also, on the CVO ultra, there are electrical connections that will have to be dealt with.
Old Sep 27, 2012 | 10:04 AM
Leveewalker
6th Gear
My Harley dealer said quick detach would not work with cvo models because of the amp mounted under the pack, my response was if this was a problem y can't it be relocated or replace amp and speakers with an aftermarket system that can be relocated. Harley had no response!! I know what it takes to remove the tour pack on a regular ultra, just hate to spend money on something that won't work.
Old Sep 27, 2012 | 11:04 AM
Buns79's Avatar
Buns79
My dealer told me the same thing when I was looking at a cvo this year, he said the service dept wouldn't even try and make the tour pak removable due to the amp... That's not saying it can't be done and I could of swore I've seen a thread on here somewhere about how to do it. Good luck
Old Sep 27, 2012 | 11:15 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Is there an amp under your Tour Pak? I know the CVO Ultra's had them in the past.
Move your amp and it can be done.
Old Sep 27, 2012 | 11:17 AM
michaelm's Avatar
michaelm
No disrespect to anyone here, but go to cvoharley.com Tons of info on this in their Ultra forum. Many have done this...
Old Sep 27, 2012 | 11:18 AM
jmorganroadglide
I thought the new cvo's had lights and a power outlet on the tourpak.
Old Sep 27, 2012 | 05:49 PM
rocksandgiz's Avatar
rocksandgiz
I believe I remember reading that the input from the radio runs to the amp under the tour pak and if the amp is disconnected you lose your radio. I'm sure it could be rewired but I'm not sure what that would do to any factory warranty. That other forum has some post of those who have done what you are talking about. Sounds like a big job.
