Increased Heat
Old Oct 2, 2012 | 09:43 AM
madmustang4's Avatar
madmustang4
Default Increased Heat
Over the past month or so i have noticed a definite increase in heat coming from the right side of the engine (left seems normal / OK).
Because the left side of cylinders seems normal, im working on the assumption that the increased heat is coming from the exhaust. If its the exhaust, what would change that would cause an increase in heat from it?
I have a 2012, 103, 2 into 1, SE air intake and had it dyno'd earlier this year.
thanks
Old Oct 2, 2012 | 09:46 AM
VTGlideRider's Avatar
VTGlideRider
Still have the cat in the header pipe? That should be the first to go. You will notice a huge improvement.
Old Oct 2, 2012 | 09:54 AM
WestTexasRanger's Avatar
WestTexasRanger
I agree: Remove the Catalytic converter or get a new/modified head pipe.
With time and after a bike is "tuned", which usually "richens" the fuel mixture, the catalyst may not "flow" as well as when new and can cause an increase in heat. It's not uncommon for the catalyst (which of course is located under your right foot) to reach temperatures as high as 700 degrees. Kind of like riding on your barbeque grill, only Hotter!
madmustang4
No cat, its a supertrapp 2:1. Also should have noted that im hearing more popping when i shift. didnt do that earlier this year.
Old Oct 2, 2012 | 10:07 AM
KCFLHRC's Avatar
KCFLHRC
That sounds like an exhaust leak, maybe re torque the header nuts.
Old Oct 2, 2012 | 10:22 AM
pontiac69's Avatar
pontiac69
2nd that. Since nothing has changed look for an exhaust leak of some sort.
Old Oct 2, 2012 | 10:24 AM
madmustang4
re torqueing sounds like a good idea. do you know the correct torque on exhaust?
thanks
Old Oct 2, 2012 | 10:26 AM
KCFLHRC's Avatar
KCFLHRC
thanks
Looks like 100 to 120 inch lbs. Not foot lbs. but inch lbs.
Old Oct 2, 2012 | 10:49 AM
KCFLHRC's Avatar
KCFLHRC
Maybe check the tightness of the bolt where the muffler bolts on too.
Old Oct 2, 2012 | 11:02 AM
madmustang4
thanks to all for your input and help
