I also made my own. 2-U-nuts, 2-stainless steel button heads 5/16 -18 (1-1/4") and 2 5/16 lock washers from Ace Hardware. I only use one on each side in the rear and use the stock pins on each side in the front. Takes less than than 2 minutes to take them all out. Cost less than 10 bucks.
That's the only reason I haven't already done it. I have to take off the right bag to check tire pressure, and the left bag to air up the suspension for two up riding. Would be a major pain in the butt as much as I take the bags off.
You can get to your shock valve by just opening the lid on left saddle bag. You shouldn't need to take it off. I check my tire pressure by rolling the bike so the fill valve is just below the back fender.
Same here...but i went wiff black chome hard ware so mine cost round 40$. Damn that shiny stuff!
By all means, bolting the bags on, you will less likely loose a bag while your riding down the highway because you didn't install the stock pins correctly. But honestly, if you can pop the lid when it's locked so easily, how are bolts going to stop a thief from taking them. Brukus security bolts, now that's a different story. They cannot be removed with a screwdriver or wrench. You need their tool, so unless the thief has one, the bags are staging or maybe he will take the whole bike instead.
I've noticed that on other bikes. For some reason, mine sits quite a bit below the top of the bag, with the lid open. I can barely get two fingers in there to put the cap back on when I forget about it.
The air valve is located and accessed at the left fiberglass side cover on my 96 RK. It protrudes through a hole in the cover and is mounted to frame behind cover. Easy to get at, no bag lids involved at all. Why does Harley have to screw with something that works just fine. Having to open the lid to fill air shocks means they located it in a stupid place, period.
It is only a torx bit, no different then carrying a screw driver or wrench for that matter.....if they're cracking the lids, nothing will stop em, I believe its a matter of, if its a pain in their *** they'll flock off and go for something easier.
