Oil Temp Question
Old Oct 8, 2012 | 04:38 AM
katobird's Avatar
katobird
Default Oil Temp Question
Before I get the microscope, molecular breakdown, get a cooler,use this brand of oil instead..... bullshiiitt responses.
I'm just looking for info...or if anyone else noticed this
I use Mobil V twin in all 3 holes...
I decided to try Mobil 15-50 for 5,000 miles.....( just crackcase)
I was on a 4200 mile trip in September and the first day it reaches 85-90 degrees, no big deal...
V twin usually run at 220.......15-50 ran at 240+
I got stopped at a few lights and noticed the temp 240 and climbing.
It stopped around 250-260 when i starting moving again.. After that I monitored it closely thinking a problem?,,,
Nope It just heated up quicker but also cooled down a bit slower
Bottem line is the Mobil 15 50 ran 20 degrees or more hotter than Mobil Vtwin.
It was a 16 day trip and I will be going back to V twin
Old Oct 8, 2012 | 05:15 AM
bklynbob's Avatar
bklynbob
The mobil oils are very similar,i believe the 15-50 has a tad more moly,though. Don't use motor oil in your tranny,use a good syn gear oil..............
Old Oct 8, 2012 | 05:26 AM
Shredding rubber's Avatar
Shredding rubber
That's funny since their spec charts are almost identical except for the moly. They are so similar in fact that the crew at bob is the oil guy feel they are the same oil with moly added to the 15w-50.
All of Mobils products have been cheapened though. I wouldn't buy anything with their logo again.
And the reason the oil temp increased is because the oil absorbed more heat and dissipated is,whereas the thicker oil just let the metal stay hotter.
Thinner oil absorbs heat faster,removing it from the engines metal. Low oil temps don't always mean good things. Thicker oil takes longer to heat up so the engine holds the heat longer.
Old Oct 8, 2012 | 06:10 AM
RK Joy's Avatar
RK Joy
My TC88 used to do around 230-235 on dino oil but dropped to 215-220 after the switch to Syn3. I don't have a temp gage on the 103.
Old Oct 8, 2012 | 06:39 AM
gregmay's Avatar
gregmay
I use 15w50 with no problem, mobil1 or napa. Had a uoa done with mobil 1 and it worked great, and it is a 50wt like the vtwin. The 15 vs 20 is what it flows like when cold.
Old Oct 8, 2012 | 06:56 AM
Rickl's Avatar
Rickl
Not to start a huge pissing contest, but it seems to me Harley themselves run Syn3 in all new CVO's. If the manufacture puts it in and recommends it (which Mobil also states) who am I to question using it in all 3 holes. The beauty is each to their own! Run what you want just don't think because someone doesn't conform to your personal decision, it's a bad decision.
As a matter of record I have run Mobil V Twin in all 3 holes without issue.
Old Oct 8, 2012 | 08:48 AM
sgod1100's Avatar
sgod1100
Your oil is at 230-235? wow...my cylinder head temp is at right around that temperature and I use mobil 15-50
Old Oct 8, 2012 | 09:13 AM
rossn2's Avatar
rossn2
Someone please correct me if I'm wrong...but 15w-50 or 20w-50 oils are NOT 50 weight oils.
A 15w-50 oil is 15weight oil or 20w-50 is 20 weight oil that has additives so they have the characterists of a 50w oil at operating temperature???
Old Oct 8, 2012 | 09:33 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I'm also curious and want to learn how heat transfer is performed in a 'better engine oil' and I found the following report:
Heat transfer characteristics of some oils used for engine cooling
Hosny Z. Abou-Ziyan
The abstract seems clear, even without a scientific approach:
<< Comparing the results of the tested oils revealed that the oil that has the largest concentrations of boron, magnesium, phosphorus and zinc with low concentration of calcium yields the best heat transport characteristics among the other tested oils. These additives provide superior detergent and dispersant characteristics, reflected in the large alkalinity and low corrosivity of the oil. On the other side, calcium has a negative interaction with other additives and yields an adverse effect on heat transfer characteristics even when it exists in oil with large concentrations of boron, magnesium, phosphorus and zinc.>>
It seems blending motor oil is like preparing a salad dressing: a few more drops of vinegar (calcium) can alter the sauce (oil) but in the end nothing matters more than saving the catalytic converter...
Old Oct 8, 2012 | 12:39 PM
iclick's Avatar
iclick
I would attribute any difference to conditions, not the oil itself, as the two oils are very similar in specs. The 15w50 has more moly, which is a plus, but slightly less zinc and phosphorus--so it's probably a wash. OT can change with air temp (obviously), speed, humidity, as well as the wind direction. I think altitude might also be a factor, as thinner air density means less ability to transfer heat. (Any ME's care to comment on that?) It would be difficult to conduct a test comparing OT between two oils except in laboratory conditions. I've seen it change 20° at highway speeds by simply changing direction with even a moderate wind.
