Tired of the pushbutton....
Old Oct 10, 2012 | 02:21 PM
D1gger's Avatar
D1gger
X2!
Unless you luck out and find the one dirty, loose connection, you will always have this problem until you either replace the wiring harness in your bike with all new or add the relay like outlined above. Don't trust the bike's voltage gauge, they are only close, not real accurate. They give you an idea of how much voltage is getting to the gauge through the 16 year old wiring harness. Read through that thread above all the way, it has many useful posts with lots of good information, from adding the relay to cleaning the solenoid and making sure everything else in the starting circuit is up to par. Adding the relay will most likely fix your problem for good, and only costs a few bucks for the relay, connectors and wire. Much cheaper than throwing a starter at the problem only to have it keep occurring!
Old Oct 12, 2012 | 03:51 PM
horse55's Avatar
horse55
Thanx for the advice we will put it to good use....
Old Oct 16, 2012 | 06:51 PM
horse55's Avatar
horse55
Ok another question... there is three wires on the starter... The two on the main connect and the one on the tickle wire... Neither wire seems to be a 14 gauge wire so again I am curious are we to attach the wire to the main connect or the small connect... and my 50 amp breaker is under the seat so the side cover location is out... just want to be sure before I starting having beer ... Alot of beer...did I mention beer....Pictures would be great....lol.
Old Oct 17, 2012 | 08:18 AM
horse55's Avatar
horse55
And it seems that my starter relay is under the fairing......hmmm
Old Oct 17, 2012 | 09:49 PM
D1gger's Avatar
D1gger
First of all your bike is a 96 classic what? The starter relay is near the starter, not in the fairing. Look near the main breaker for it.
Old Oct 18, 2012 | 10:15 AM
horse55's Avatar
horse55
In the Harley shop manual there are two relays under the side cover on the right side and they are electronic fuel injection ...1996 Classic Standard is what this thing is and the schematic shows the starter relay on the right side under the fairing looking at the bike from the front... And yes the 50 amp relay is under the seat just ahead of the battery...
Old Oct 18, 2012 | 01:55 PM
D1gger's Avatar
D1gger
Originally Posted by horse55
I have replaced the switch and the breakers and the starter and solenoid....I was told I could fix the problem with a wire 2 feet long but I don't know where the wire is supposed to go...
If you replaced the correct switch, breakers, starter and solenoid, you're left with a bad connection, bad ignition switch or bad battery.
I have replaced the starter switch and the starter and all the relays in the circuit so I am running out of options other than a rewire job....
Okay, still possibly a bad connection, bad ignition switch or bad battery, at least this time you say you replaced ALL the relays as well, which is good.
If you don't know the difference between battery cables and smaller gauge wiring, you really don't need to be trying to do this yourself.
Didn't you say you already replaced it? If you actually haven't yet, you should. That could be the problem.
I guess you didn't replace any relays yet. If you don't know the difference between a relay and a circuit breaker, you really don't need to be trying to do this yourself...
Old Oct 18, 2012 | 05:18 PM
horse55's Avatar
horse55
What I said was I have replaced the switch ( pushbutton) on the handlebar.. the relay under the fairing the 50 amp circuit breaker and I had the solenoid rebuilt and the starter rebuilt before I replaced the starter with a new one..... And I did all the work myself... So I know the difference between the two... There is a wire that connects to the main post with the cable and then a small 14 gauge tickle wire I am just tired of trying to find the problem and I want to be sure where your going ....
Old Oct 18, 2012 | 05:38 PM
Gliden's Avatar
Gliden
Wow what happened here.....? You said you have 12.5 volts on the hd gauge under way.
You now need to get a true rms volt meter and test your charging system at the battery while she's running over 1500 rpm.
If you don't see > 14 volts no greater than 15.5 you have a problem.
Regulator or alternator problem. 12.5 volts ain't cutting it and if that's all your getting look no further. Youve identified your occasional no crank issue.
If I missed a post I'm sorry but I just couldn't read all of them.
Old Oct 18, 2012 | 05:49 PM
vheflin's Avatar
vheflin
I'd recommend fully charging the battery and having it load tested. Ideally the battery should be fully charged prior to a load test. I've had my local dealer to this for me and they like to have the battery dropped off so they can charge it overnight and test it the following day to get the most accurate results.
If the load test fails, get a new battery otherwise I'd check the battery terminal voltage with the bike off. A fully charged battery should read 12.6 -12.8 volts dc or slightly higher. Start the bike if you can, and record the voltage with the record function of the multimeter if this feature is available, while starting the bike. The voltage should not drop less than approximately 9.6 volts. Check the voltage with the engine at idle. At idle your voltage should be about 14.5 - 14.7 volts dc. If not, rev the engine to 2000 rpms and recheck. This will let you know if the battery is being charged.
If the battery is not being charged you will need to check the charging system. There are several posts on this forum on how to do this.
If battery is being charged. I'd recheck all connections, fuses, relays etc...
You might want to remove and reseat the starter relay or even replace it just to rule it out. Minimal cost for a starter relay.
