Rear lowering kit
Old Oct 11, 2012 | 01:51 AM
1Bushmaster's Avatar
1Bushmaster
Default Rear lowering kit
Anyone put a lowering kit on the back of their Road King? It's just a little too tall for me. Thanks
Old Oct 11, 2012 | 03:35 AM
Spartacus55's Avatar
Spartacus55
The best way to lower the rear on your bike is to buy stock harley shocks that are one inch lower. This way you do not screw around with the geometry of the rear which alot of people do when they just put those rubber blocks in.
Old Oct 11, 2012 | 04:33 AM
grbrown's Avatar
grbrown
The answer to your question is that Yes, they do, although I wouldn't. If it is only a little too tall I suggest you take the time to get used to it! Wear good quality riding boots to give you a good footing and ride!
Old Oct 11, 2012 | 06:16 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Got a LA Chopper Kit for sale if you decide to go that route.............Just don't use it with Ohlins or Progressive Shocks...
Old Oct 11, 2012 | 08:30 AM
JohnnyC's Avatar
JohnnyC
I moved to shorter HD air rides dropping from 12" to 11", and taller cycle boots.
You don't want to "get used to it" being too tall. Safety wise you should be able to put both feet down flat on the ground when seated.
Some also get different seats or have theirs reworked. Lowering your seating position and moving slightly forward gives you safe control of your ride!
WARNING: My ride originally had the lowering blocks and both air shocks were damaged do to the changing angle, and unusual repositioning. One shock the whole bottom mount broke away due to those lowering blocks.
Old Oct 11, 2012 | 01:39 PM
rowle's Avatar
rowle
I bought the blocks to see if the 1" drop was what i was looking for. It worked fine but i went and bought the shorter shocks as the angle changes - and that cannot be right .....??
Might be worth the 20 bucks to see if the drop is what you need.
Rowle UK
Old Oct 11, 2012 | 01:50 PM
baust55's Avatar
baust55
I am short . I had my seat lowerd and narrowd buy MeanCity Cycle . very thrifty total cost just under $150 .Including shipping both ways.
I had a cobbler make my boot heels and soles thicker .
This might take care of it fore you ..
I also got some 11" Bitchin Bagger Drop Shocks theses are stock shocks cut down ..
I aslo put a wedge thingy on my kick stand mount because the shorter shocks made the bike stand up to straight .The wedge kit got it to lean over the right angle on the kickstand way cheaper than buying a shorter kickstand .
I also had trouble getting the kick stand up and down .. i got the HD kickstand exstention $30.
Old Oct 11, 2012 | 03:14 PM
Hrd Rider's Avatar
Hrd Rider
My 2012 EG wasn't comfortable for me after stepping up from a 2008 Heritage so I went with the HD Low Profile 12" Shock Kit & the Low Profile Front Lowering Kit. It definitely lowered the bike but the ride was a little too harsh for me so I went back to the original shocks and frt fork springs. Sent seat to MCC and had it modified, for me that worked. In fact I have my Frt & Rear Kits for sale in the HD classifieds. My weight 185 lbs & 30" inseam.
Old Oct 11, 2012 | 03:21 PM
Tee Bagger's Avatar
Tee Bagger
I have the la chopper kit...it is top of the line!!! Does not change the geometry of the shocks, and they do not rub like some of the cheaper kits. I would highly recommend them.
Old Oct 11, 2012 | 03:25 PM
kmayHD's Avatar
kmayHD
1" drop blocks on mine. No problems for me, also C&C fastback seat, gotta be 2" inches lower than stock at least. Im 6'2", works fine for me.
