I don't think I would pay extra for a battery that does not give me any extra advantage. Li-ion does not last any longer than lead/acid, it does, just like lead/acid perform less good in cold weather and doesn't like heat any more either. It is however, lighter so, if you have to push your scoot a long way down the road, you want this battery.
Hmm, The info I read was it lasted 3x longer, and the temp range was 40-140*F. It doesnt need to be put on a trickle charger. So if it lasted 3x longer do the math, money wise it is less.
Tried to start the glide today...and the the starter sounded like it jammed solid (a loud clank)! I waited a second and then it turned over again and it started (but it struggled..as if i've increased the compression). Its been close to 3 years on the original battery...is this the sign of a weak battery..or something worse??
Don't run out and buy a battery just because it's 3 yrs old and cranked a little slow. Do you use a trickle charger? What is the battery voltage with the ignition on before you crank it? If you don't use a trickle charger, your battery may just be a little low. Recommend you give it a good charge before you spend a penny.
I've had the loud clunk twice. HD Techs tell me it's the starter clutch and is "normal" whatever that means. I assume it will be "normal" right up until it "breaks"
Not my own wisdom but reading stuff like this and owning a '07 Ultra going stong on it's first battery makes me think twice.
Disadvantages
Charging forms deposits inside the electrolyte that inhibit ion transport. Over time, the cell's capacity diminishes. The increase in internal resistance reduces the cell's ability to deliver current. This problem is more pronounced in high-current applications. The decrease means that older batteries do not charge as much as new ones (charging time required decreases proportionally).
High charge levels and elevated temperatures (whether from charging or ambient air) hasten capacity loss. Charging heat is caused by the carbon anode (typically replaced with lithium titanate which drastically reduces damage from charging, including expansion and other factors).
A Standard (Cobalt) Li-ion cell that is full most of the time at 25 °C (77 °F) irreversibly loses approximately 20% capacity per year. Poor ventilation may increase temperatures, further shortening battery life. Loss rates vary by temperature: 6% loss at 0 °C (32 °F), 20% at 25 °C (77 °F), and 35% at 40 °C (104 °F). When stored at 40%–60% charge level, the capacity loss is reduced to 2%, 4%, and 15%, respectively. In contrast, the calendar life of LiFePO4 cells is not affected by being kept at a high state of charge.
The internal resistance of standard (Cobalt) lithium-ion batteries is high compared to both other rechargeable chemistries such as nickel-metal hydride and nickel-cadmium, and LiFePO4 and lithium-polymer cells. Internal resistance increases with both cycling and age. Rising internal resistance causes the voltage at the terminals to drop under load, which reduces the maximum current draw. Eventually increasing resistance means that the battery can no longer operate for an adequate period.
Aloha All, I dropped the extra coin ($350) for a Shorai brand Lithium Iron Prismatic Cell (LifePo4) battery for my 08 Police Model Road King (103 ci). If youre interested, the numbers from their website are as follows; Sku: 4897034420395 and Part Number: LFX36L3-BS12. The battery is about half the size (they include foam padding to fill the empty space) and it is super lite compared to the stock battery. I went through the Harley battery in less than three years. I bought the bike used and had to put a battery in right after I shipped it to the west coast. I ride at least 6 days a week, yes because I can! I hope at a $350 price tag, I can get a least five years out of it. Anybody have one of these batteries in service that long yet? If not, I'll let you know in 2017 if it made it the five years I'm looking for. Needle
Had a Sears Diehard that lasted about 3 yrs. but leaked all over a $600 Super Trapp muffler set. Next got an AGM from JP Cycles that lasted 13 mos. with a battery tender on it in the winter. Now have an AGM from O'Reilly's Auto Parts but am trading the 'ole girl in on a 2007 FLHP very soon.
I have had excellent service from Odyssey AGM batteries in my two personal watercraft. The increase in cranking amps spins the starters noticeably faster. I find it hard to believe that the one in my stand-up is 15 years old and still going strong. When they die, I will definitely get another one.
I would be happy if it lasts half as long as my PWC batteries. The only downside is that it is a little smaller than the standard battery. I had to make some spacers. I used rubber conveyor belt material.
Another thing I like about AGM batteries is that there is no need for a vent tube. They are completely sealed and I have never had any corrosion anywhere while using them.
I got a great deal from this outfit! Cant beat the price.
I use the odyssey pc925 for 6 years, and it still performs yell beyond Harley batteries. Starts right up at 16 degrees (coldest I rode to work). Highly recommended.
...I agree..man, if I had to buy a battery every 3 years, I'd be PISSED!...I'm going on 8 years this May on mine...still has plenty of umph....kept in heated garage during winter....charge it up, then put a load test on it...they should last 4-5 minimum imo...
I got 4 years out of my stock HD battery on my Dyna before I traded the bike in. It was still going strong at the time. It was garaged and kept on a battery tender most of the time.
