Fork nut tool
Old Oct 19, 2012 | 04:44 PM
glcash's Avatar
glcash
Default Fork nut tool
Does anyone know the part # if harley even has one for the 35 or 36mm tool that loosens up the nut on top of the forks?
I've looked online. Can't find it. Need to swap out the forks on my 2010 street glide.
Old Oct 19, 2012 | 05:20 PM
leeroynakd's Avatar
leeroynakd
should be one in the tool kit you got with the bike.
Old Oct 19, 2012 | 05:41 PM
TripleSix's Avatar
TripleSix
12" crescent wrench
Old Oct 19, 2012 | 05:47 PM
jjnoble's Avatar
jjnoble
Harbor freight, $10 or so. HD $100 or so.
Old Oct 19, 2012 | 06:09 PM
James K's Avatar
James K
http://www.motionpro.com/motorcycle/partno/08-0139
If search around you may find it cheaper.
Old Oct 19, 2012 | 06:16 PM
glcash's Avatar
glcash
Bike was used. Did not come with a tool kit. Ok I'll check harbor frieght & motion pro.
Old Oct 19, 2012 | 08:13 PM
2black1s's Avatar
2black1s
On batwing bikes a socket will not work because there just isn't enough room to get a ratchet or other drive mechanism in there. If the socket had a hex on the outside, similar to a spark plug socket, that you could turn with another wrench, it would probably work.
Simplest solution... Get a 12 point 1 3/8" box end wrench. You can do it with a open end or adjustable, but it's tougher because you don't have much swing room.
Old Oct 19, 2012 | 09:17 PM
glcash's Avatar
glcash
I figured that.
Old Oct 20, 2012 | 11:53 AM
princeaz's Avatar
princeaz
From: Payson, AZ within 400 miles of the best the west has to offer for riders
Amazon.com $35.
Old Oct 20, 2012 | 02:17 PM
fat daddy's Avatar
fat daddy
JP Cycles has the socket you need. Makes the job go easy and you can get the correct torque on the nut.
