B+ Connector
Old Jan 29, 2007 | 10:59 AM
Tin Man 1's Avatar
Tin Man 1
Default B+ Connector
I have a 2007 Ultra Classic. Can anyone tell me what the gray connector located in the Upper Frame Cross Member (Under Seat) is? The service manual shows that it is B+ Connector (160). There is nothing connected to it, but I don't know what it's for.
Thanks
Old Jan 29, 2007 | 12:13 PM
SteveO's Avatar
SteveO
Default RE: B+ Connector
It is an accessory hook up and is fused. You can purchase the maiting connector from HD.
Old Jan 29, 2007 | 12:59 PM
Tin Man 1's Avatar
Tin Man 1
Is this connection always hot? Does the ignition switch need to be on? And will the H-D Electrical Accessory Adapter 70270-04 connect to this?
Thanks again.
Old Jan 29, 2007 | 01:07 PM
Edelmon's Avatar
Edelmon
You turn it on with the accessory switch on the handlebars. I have a road zeppelin seat plugged into mine....
Old Jan 29, 2007 | 02:41 PM
SteelCityScooter's Avatar
SteelCityScooter
ORIGINAL: rickpeg
Thanks
You have TWO free connectors under your seat.
B+ Connector [160B] which is a NONE FUSED main wire harness circuit(It is protected by the 40 amp maxi fuse), it is directly downstream of your voltage regulator(Comes off #2 terminal of connector[77B])and is the same circuit that supplies the ignition switch power.
It is a 1 Place PackardConnector.(Red Wire)
Accessory Connector [4A] is theother connector under the seat, It is a fused accessory circuit, that is turned on and off with the accessory switch with the ignition ON.
It is a 4 Place Deutsch Connector (wire colors#1 O/R, #2 R/Y, #3 O, #4 BK)
Old Nov 12, 2007 | 11:43 PM
thatguy's Avatar
thatguy
Where is this connector? .... I can't find it on my '08 Classic. Supposed to be under the seat somewhere.
Old Nov 13, 2007 | 04:37 AM
Tin Man 1's Avatar
Tin Man 1
I haven't looked under the seat of a '08, but on the '07 it is under the seat, in front of the battery. On mine there is a bundle of wires stuffed in a cavity there. Taking these out should reveal the B+ Connector and the Accessory Connector.
Old Nov 13, 2007 | 10:30 AM
thatguy's Avatar
thatguy
Thanks, I will look again.... my ECM is attached to the top of the battery - so are u saying to remove the battery and look there?
Old Nov 13, 2007 | 10:55 AM
YodaddyKeith's Avatar
YodaddyKeith
The +B connector is a single wire connector(gray) located in cavity in front of seat on most models.It's hot whenever bike is in ign,or acc switch mode....It is Not switched separately-if the ign is switched on or in acc position, then the +B is hot, so angthing you connect to +B that requires a switch must offer it's own ground and provide it's own switch.
In the same area is another connection that is called the Acc plug/jack......It is black and larger plus it is protecet by a rubber seal plug attached to it multi condictors by an anchoring strap....The Acc plug is switched and offers it's own ground.
The touring bike crash mount fog light kit offered by Harley should be connected to the +B connection....The lighting kit includes a relay, a switch and it's own ground circuit.....However, on many touring bikes, the lighting harness connection will not plug directly into the +B connection on the bike.....If you run into this problem, simply remove the lighting harness wire terminal spade fron the connector and plug the bare spade into the +B on the bike....The bikes +B connector is designed to accept the spade and also locks it into place and provides built in short protection for the bare male spade.
classic-al
Dec 31, 2012 02:39 PM
07FLHRCMarinePatriot
Mar 24, 2012 03:32 AM
grummie
Electrical/Lighting/Alarm
Dec 13, 2011 07:23 AM
cbtruckin
Mean City Cycles
Oct 22, 2008 10:27 AM
raclos
Mar 21, 2007 07:25 PM
