2007 Ultra Classic Wiring Diagram
Old Dec 29, 2012 | 08:55 PM
classic-al's Avatar
classic-al
Stage II
Default 2007 Ultra Classic Wiring Diagram
Hi Folks - I have just bought a 2007 Ultra Classic. On reading the owners manual it says it has a 12V DC accessories outlet (aka a cigarette lighter) hard wired in under the seat and connected to the ACC switch on the dashboard. Having looked under the seat, the outlet is not present but when the ACC switch is made, it does illuminate. I have work arounds (use the cigarette lighter on the fairing or wire in a splitter lead to the battery tender pigtail) but neither of these allow me a permanent solution utilising the ACC switch circuit. I would like to wire in a cigarette lighter to the ACC circuit to power my GPS and wondered if anyone has a wiring diagram they could post.
Best wishes and thanks
Classic-al
Old Dec 31, 2012 | 02:35 PM
UltraNutZ's Avatar
UltraNutZ
you can do this a lot easier that going back to the seat location. That plug is in fact there, it's probably just hidden down in the area in front of the battery.
On the acc switch itself the wire you want is orange/red stripe. Simply tie that wire into the center pole of your cig lighter, then ground the outside to your fairing bracket.
Old Dec 31, 2012 | 02:39 PM
Scaredofrain's Avatar
Scaredofrain
Right hand side panel slightly to the front is where you should find it.
Bradley Jones
Apr 17, 2010 07:00 PM
kennyross
Sep 28, 2008 06:48 PM
Bldr1000
Oct 27, 2007 02:15 PM
gordo 2050
Sep 3, 2007 02:05 PM
jbatp92
Sep 12, 2006 04:44 PM
