ACC switch on Ultra
Old Sep 2, 2007 | 01:18 PM
gordo 2050's Avatar
gordo 2050
Default ACC switch on Ultra
Does anyone know if there is a wire or plug connected to this switch? I am thinking of adding an xm but I need a power source. I would like to power off the ACC switch.
Thanks
Old Sep 2, 2007 | 01:20 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: ACC switch on Ultra
Under your seat - in front of the battery there is a opening - it should be in there with a cover
Old Sep 3, 2007 | 01:57 PM
ricoman's Avatar
ricoman
It's probably dark grey or black. 4 wires into it. Check your manual wiring diagram for the wire thru the switch. Some years use orange/red. You can get the post to crimp on the wireto your device, the rubber shield it pushes thru and hold it into the connector, and the male end to mate to the connector from your dealer. There may be an existingcover on the connector that will need to be removed and tossed so the male end with the new wire will clip in. It will likely run thru the 15 amp "P/A" fuse in the fuse block.
Disconnect the battery (neg. 1st) before you start. The battery may need to be removed to get to the connector.
Old Sep 3, 2007 | 02:05 PM
MNPGRider's Avatar
MNPGRider
Air and heated seats plug into the switch, under the seat. There is also a part in the Harley catalog for a splitter, making two plug-in's out ofone.
When I got my Air Zeppelin, I had a heckuva time plugging it in. I cut all the wire ties in the immediate area, and freed up a lot of slack in the wire harness around that plug in, and then retied.
Bubba Zanetti
Apr 4, 2017 10:06 PM
Mr. Clean
May 17, 2013 11:40 AM
07FLHRCMarinePatriot
Mar 24, 2012 03:32 AM
SteveO
Mar 28, 2011 08:32 AM
Bradley Jones
Apr 17, 2010 07:00 PM
