I work as an inspector, part of my job is calibration of gauging equipment. I can tell you that the ratchet style t-wrenches that Harbor Freight sells are terrible. Spend the money to get a quality wrench like a Snap-on etc.
Some auto parts stores will lend, or rent a quality wrench if you're only going to use it once.
i've read more than a couple 'professional' reviews of torque wrenches that show the harbor freight closer in spec to several high end torque wrenches. with snap on being one of the worst.
Probably real bad advice giving an amateur mechanic advice to go by feel. That comes with years of experience, if even then. So go buy a good torque wrench, because these guys that say go by feel aren't going to be anywhere around when you snap off a bolt. You ever seen those pit crew guys on the NHRA races that tear down and rebuild a top fuel engine in under an hour going by feel? Hell no you don't. About as ridiculous as hand tighten then 1/4 turn, you going to do that on an axle nut? Doubt it. How did Daddy die mommy? Well he was to damn cheap to buy a torque wrench and his wheel came off. Now go get the nanny so I can go out and spend more of Daddy's life insurance money.
In my opinion never buy a precision tool from harbor Freight. Im not a hater of their stuff but the in/lb torq wrench I purchased was useless and did not work. I'm no master mechanic or anything but I try to do all my own work, and have some hit and miss with Harbor Freight.
Since when did installing pipes become a life or death situation? Of course if you are doing engine/trans work you should torque to specs but something as insignificant at slip on's wont make or break anything. You are over exaggerating. Buying a torque wrench from Harbor freight and expecting it to be worth a sh*t in my opinion is far worse than going by feel, especially on something as insignificant as pipes.
I know what I would do if I didn't own one-----------------find a garage mechanic that builds automatic transmission and have him torque them for you.As far as the poster saying the snap on being the farthest off torque I would be curious where those fact came from----------------------there are several independent calibration shops and my snap ons have been less than 2% since I bought them in the 70s.Click type on all but the inch lb one and its a dial type .I calibrate it against my small 1/2 drive before I use it as well as send them off yearly for calibration
Think this calibration is pretty silly for normal work unless you use your wrench as a breaker bar. I build submarines for the last 46 years and cut up so many brand new Snap on torque wrenches I lost count that failed to pass calibration new out of the box. However the tolerance we required was really way too tight. Few lbs here or there makes little difference. The video above looks staged since no one torques a lug nut to 30 lbs and it is actually pretty difficult to break off a stud with the short handle on the 1/2" drive wrench in the photo. That guy would have had to jump on it. Someone who does not know the difference in 30 lbs and the 200-300 it took to break that stud off should pay someone to work on their bike.
You might want to actually listen to the video, it isn't a lug nut. It's a caliper bolt.
