Bagger nation rf system for ultra
Old Oct 30, 2012 | 02:35 PM
lhgdale's Avatar
lhgdale
Default Bagger nation rf system for ultra
Hello, I posted this in the audio section and got some good info from UltranutZ but wanted to see if anyone else was running or heard this system? I am drawn to this setup because it is a complete kit and as mentioned below I am a audio novice.
Hello, I am a audio novice at best but love music while I ride and like it loud and clear. I am looking at this system from bagger nation. Just looking for some opinions and feedback on the setup. Thanks
Here is a link: http://www.baggernation.com/products-stereo.htm
The Bagger Nation Ultra “Supreme” 75EX System Our latestcompleteStereo system catersto loversof UltraClassic Models! This system replaces the stock in fairing speakers with our fantasticPower 6.5” coaxial speakers and also upgradesto tour pack speakerswith Power coaxial 5.25 speakers. Thenew RF 300x4 Amp makes thisan *** kickin’, affordable sound system available foryour Ultra. Each kitincludes(2) 6.5 Rockford Fosgate “Power” coaxial speakers /A set of6.5” Speaker adapters/ (2) 5.25” Rockford Fosgate “Power” coaxial speakers / a Rockford BRT 300x4 amp / Our exclusiveHard mount heatsinkfor the amp and a complete wiring harnessand step by step instructions!. This system will provide you with amazing sound clarityand volume capabilities you’venever heard from a motorcyclesound system! It’s also expandable so if later you wantto add a set ofAudio Lids w/6”x9”s or some 6.5”s to your fairing lowersyou’ll have 2 extra channels on your amp to do it. So ifyou’relooking for some kickass curb appeal for your Ultra Glidesound system or you just simply would liketo be able to rockoutat highway speeds, look no further... The Rockford Ultra Glide Super Stereo will blow you away! Complete wiring harness, hard Amp mountand heat sink and step bystep instructionsincluded! This complete system is exclusively available from Bagger Nation and will blow your mind!
Part #RF300x4-UGSS Bagger Nation UltraSupreme 75EX System Price: $629.95
Each KitIncludes: •Hardware •Mount/Heat Sink •Wiring Harnessand •Step byStep Instructions
Old Oct 30, 2012 | 04:20 PM
UltraWalt's Avatar
UltraWalt
I looked at that as well but decided to piece it out myself and saved a pretty good chunk of change. Went with different speakers in the fairing and no plans just yet to replace the rear speakers as I understand you don't get the bang for the buck on the rears.
Old Oct 30, 2012 | 06:53 PM
lhgdale's Avatar
lhgdale
Yeah, that is what I was told. The fronts are good but the rears are not so good.
Old Oct 30, 2012 | 07:15 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i would recommend the rock for 2 channel 2 ohm amp,with your choice of 2 ohm speakers,unless u plan on running 4 speaker.it will sound good and save a lot of dough.the wiring isn't very difficult all u need are power and ground (kit at best buy)and some speaker wire with some crimps.
Old Oct 30, 2012 | 08:15 PM
lhgdale's Avatar
lhgdale
I will be running the fairing speakers and the passenger speakers.
Old Oct 30, 2012 | 08:20 PM
bigdumbnoitall00
the rockford 4 channel amp can be had cheaper,u won't get wiring or a mounting bracket,for the bracket many use velcro and put it ontop the radio,if u don't feel confident or know someone to help with wiring the kit may be the way to go,u will still have to wire but it comes with instructions and the wires.hardest part for me was pulling the tank to run power from battery.
Old Oct 30, 2012 | 08:57 PM
Pioneer74's Avatar
Pioneer74
Be aware that those speakers are not marine grade. They also have a low sensitivity rating.
You can piece it out cheaper than the package they sell, but you will not get the wire harness and amp bracket. The wiring is that that difficult, just order a Fosgate 10 gauge amp install kit.
Old Oct 30, 2012 | 09:06 PM
lhgdale's Avatar
lhgdale
Is there another package out their you would recommend? I want to do this right the first time. My max would be around 750.00. The RF speakers not being marine grade would not do well being exposed to water?
Old Oct 31, 2012 | 01:18 AM
Glockmeister's Avatar
Glockmeister
The info above sounds pretty definitively against your package deal, might do more research. If I wasn't deaf as a stump I'd probably be doing this too, but as it is, I can't hear myself thinking.
Old Oct 31, 2012 | 06:51 AM
Timmy B's Avatar
Timmy B
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
I went with the house party system for the road glide with all punch speakers, and repleced the tour pack speakers as well (punch as well) I added the HOG TUNES tweeter pod so it is a ten speaker system. I had it custom installed on my Ultra -Lmited, face melting!!! Love it, the custom work done for the install was a little pricey but worth it for me!!!
Attached Thumbnails Bagger nation rf system for ultra-002.jpg   Bagger nation rf system for ultra-003.jpg
