Windshield Bolt Help
Old Oct 31, 2012 | 09:00 PM
Airborne Limited's Avatar
Airborne Limited
Default Windshield Bolt Help
Got in my new National Cycle VStream windshield today. A little upset because they sent me the clear rather than the light tint I ordered so it's going back to swap out, but that's another story. My issue is that this windshield seems to be a little thicker than the wind splitter it's replacing and with my windshield bags it seems I need longer batwing windshield bolts. Can anyone provide a part number or the bolt's dimensions so I can find the proper size bolt in just a longer length? Thanks.
Old Oct 31, 2012 | 09:52 PM
Airborne Limited
Bumped up
Old Oct 31, 2012 | 10:01 PM
jus2anoyu's Avatar
jus2anoyu
Most dealers have a really nice bolt selection. Take one of your old ones and tell them what you need. They should have exactly what you are looking for. Same torx head and show chrome...
Old Oct 31, 2012 | 11:51 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Stock windshield screws are 1/4-20 X 1/2" - Get the 1/4-20 x 3/4" length and it works fine. Chrome buttonhead allens look the best. Many bike shops & auto parts store carry these.
Old Nov 1, 2012 | 12:09 AM
2black1s's Avatar
2black1s
1/4-20 is the correct diameter and pitch. I have a National Cycle shield and the extra thickness is only about .050" or one thread of a 20 pitch thread. The stock bolts work fine for me but I have no windshield bags.
I'm assuming that the winshield bags must also attach in the gap for the windshield. If that's the case I would measure the thickness of the bags, add .050 for the winshield, and get a bolt close to that much longer than stock. Probably somewhere around 9/16" or 5/8" long.
Be careful. If you go too long you'll bottom out and either pull out the brass inserts or f up your inner fairing. I think 3/4" length would probably be too long. Finding bolts in 1/16 or 1/8 inch length increments may be an issue (I'm sure you can get them somewhere but they may not be an in-stock item). If that's the case, get longer ones and cut them to length.
Old Nov 1, 2012 | 03:40 AM
bklynbob's Avatar
bklynbob
www.depss.com
Old Nov 1, 2012 | 06:23 AM
Rickr01's Avatar
Rickr01
Stock Bolts should work fine. The only variable may be in your windshield bag?
Old Nov 1, 2012 | 07:25 PM
Airborne Limited
Thanks for all the info everyone; especially the link to depss. I was able to buy 5/8 and 3/4 length 1/4X20 polished allen head bolts for less than $10. Bought both lengths at that price just in case the 5/8 isn't long enough. Pretty sure they will be but didn't think I would find that length. Thanks again all.
Old Nov 1, 2012 | 08:26 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
I recommended the 3/4" length because thats what I sell with the the Fast Aire Chrome & Black trims. If you add a thicker windshield and a set of windshield bags, it ends up close to the same thickness as the trim.
I have checked the 3/4" w/ washers on my 07 and there are no issues with a stock 1/8" windshield with no bags.
Also, you should always use washers under the windshield screw heads or the screw heads will dig into the painted fairing... it leaves a nasty mark.
Campy Roadie
May 2, 2017 12:07 PM
VA_Larry
2014-2024 Touring Models
Jan 17, 2015 03:50 PM
IronAss
Jul 24, 2012 11:23 PM
Streetrunner
Aug 23, 2010 09:05 PM
Hossman
Apr 27, 2006 01:31 AM
