Air Pressure in Shocks???
Old Jan 29, 2007 | 11:06 PM
Fastlane's Avatar
Fastlane
Default RE: Air Pressure in Shocks???
Also check your book for tire pressure when two up or single. I always set my bike up for solo or double.
Old Jan 29, 2007 | 11:55 PM
Mac57's Avatar
Mac57
The H-D pump is worth it. I do most of my riding two-up with my wife and run 20 to 22 lbs. I should probably put in more but I'm a little paranoid about using too much and blowing a line.
Old Jan 29, 2007 | 11:56 PM
gdbro4's Avatar
gdbro4
When my '05 was new, the shocks leaked. I used a compressor to air them up, 75 miles from home. Went to the dealer, and I was told that since I used an air compressor, my shocks wouldn't be warranty, and I needed to buy a pump. I said BS. (It was only a loose hose connection). I purchased Harley's pump and it works great. I use 20-25 psi with bike loaded. Good luck.
Old Jan 29, 2007 | 11:59 PM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
ORIGINAL: HDUC1
I agree with Bountyhunter. Buy the HD pump. I run mine at 26 two and 30 loaded. It makes a difference in the ride and handling with a load.
HD pump and 30 loaded.
I put em at 35 last summer when VIcki and I rode with two suitcases strapped on top.
Old Jan 30, 2007 | 12:11 AM
SteveO's Avatar
SteveO
Buy a $23,000 bike and won't spend $39 for the correct air pump that is designed for the HD shocks? Or......like one post, guy buys the HD pump on e-bay for $30 and spends $8 for UPS and it's a used pump, but he save $1!
Go figure!
Old Jan 30, 2007 | 12:22 AM
wldbill's Avatar
wldbill
I had my 06 FLHTC lowered front and rear. I feel I should be using the pressure specs for FLHR & X models which have Lo Profile shocks. Lo Pro max load ranges from 40 to 50 while the FLHT max is only 20 to 35. The "powers that be" don't have an answer so I just put enough in when loaded up is around 25psi. Has anybody done the 40 or more?
Old Jan 30, 2007 | 12:40 AM
mcbull's Avatar
mcbull
Check at a local bike shop, you might be able to save $10 or $15. The HD pump is identical to the pumps used by Fox, Manitou, etc.to air up mountain bike suspension forks and rear suspension shocks. Like this one http://www.cambriabike.com/shopexd.asp?id=39816
Old Jan 30, 2007 | 12:49 AM
fatboylust's Avatar
fatboylust
The HD pump and presumably those noted by mcbull have the ability to disconnect with out losing the charge. I tried a less expensive bicycle pump but it wouldn't disconnect without letting the air out. Learned the lesson the hard way.
FBL
Old Jan 30, 2007 | 12:55 AM
mcbull's Avatar
mcbull
Fatboylust, good point. The HD pump and the bike suspension pumps not only allow you to unscrew the connector without losing any air pressure, they also have bleeder buttons that will allow you to bleeed air out toexactly the presure you want.
Old Jan 30, 2007 | 01:54 AM
spartns's Avatar
spartns
Get the pump. For all of the reasons mentioned above.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
