Octane question please
Old Nov 8, 2012 | 08:10 PM
mikelikesbikes's Avatar
mikelikesbikes
Originally Posted by IrishHogtrotter
maybe add octane booster if you can get some?
That is what I would do but I love my bike and I am ****.
Old Nov 8, 2012 | 09:45 PM
Krow's Avatar
Krow
In Aug we spent 5 weeks touring Newfoundland 2-up and pulling a trailer. Many ( ie Most) small towns had one grade of fuel available - 87 octane. We had no choice but to use it, sometimes several consecutive tanks of it. I was concerned at first and listened carefully for any pinging - NONE, even at speed attacking com long and steep hills! There was also no noticeable decrease in performance than when I burned Premium but I was smellin' the roses, not racing. I have an app on my tablet that keeps track of fuel mileage and could find no apparent difference there either, although nearly each day was different, with some having lots of hills, others having high speeds on the highway, and more days just cruising villages - variances seemed to me to be more about terrain/driving style than octane. I still burn 91 when I can find it - just because the few cents difference in a tank is no big deal - but no longer am I **** about it. I've seen people wait to make sure they fueled behind somebody using premium because they didn't want the residual low-octane fuel left in the line!
Old Nov 8, 2012 | 09:49 PM
Sprinter7x's Avatar
Sprinter7x
I put 87 in my "12" RK accidentally,wasn't paying attention,it ran fine.
Old Nov 9, 2012 | 04:34 AM
jus2anoyu's Avatar
jus2anoyu
Ping is your combustion trying to drill a hole in your piston. Get what fuel out can and don't be afraid to add a lot of octane booster. The bottles at the auto parts store are designed for a typical auto fuel tank, 12+ gallons, but they don't really add many octane numbers. I have used a 10 gallon dose without issue. It really depends on your tuning. If your bike isn't heavily modified, or has a slightly richer fuel tune, you may be fine without booster. Amsoil and Lucas both make a motorcycle sized bottle and both have worked Well for me.....
Old Nov 9, 2012 | 07:46 AM
Chunker's Avatar
Chunker
If you are going to buy the HD party line and all their recommendations then take note that the owners manual of my 2011 FLHTK says do not use octane booster because engine damage may result. If it's a stock engine inside and doesn't ping, using the lowest octane that does not ping is the smartest move. But your engine, your comfort zone, your wallet.
Old Nov 9, 2012 | 07:53 AM
darkcustom48's Avatar
darkcustom48
I think I'm gonna go with adding 1 gallon of 87 to average my octane to around 90. The news says gas flow to Long Island should free up soon. The gallon plus what I have in the tank should get me about 150 miles. I appreciate all the advice and suggestions.
Old Nov 9, 2012 | 08:05 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by VTL nut
You will be fine, for many have and do run up to 10% ethanol without ill effects.
Ethanol and octane rating are two different things.
HD sells an additive, not a stabilizer, that is advertised as "when higher octane fuel is not available." Most dealers stock it. It is Harley brand but I admit, don't know what is in the bottle. I've used it religiously when traveling the Midwest where 87 is considered 'premium'. No pinging. Did I need too? Will never know.
Old Nov 9, 2012 | 08:11 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Use what you can for now and get back to the good stuff when it is available. If you can find the octane boost use that in the interim.
Old Nov 9, 2012 | 10:08 AM
harley_badboy's Avatar
harley_badboy
I've put in regular gas before by mistake and noticed no difference in the way it handled. I would put it in and not worry about it at all.
Old Nov 9, 2012 | 04:58 PM
00FattyT's Avatar
00FattyT
Originally Posted by Larry64
The cooler weather will help too.
I have always heard that too. if you do alot of cold weather riding to drop octane because the higher the octane the slower the burn and when it is cold out 93 will not burn as completely as 87. I honestly think that I would rather run 87 octane 100% gas than 93 octane 10% ethanol. No evidence to either.
I would have no problems running 87 in mine for at least a tank.
