What baffle do you run? I found a Boarzilla for sale but the only mods I have done is a SE tuner, SE high flow air cleaner, SE 255cams. I just don't know if I have enough motor for it.
Boarzilla is for 113 CI and up -- in some cases may be to much for a 113
hey mike.. (or anyone who cares) kinda off subject here but I have a 2012 street glide 103 w/ stage 1. I was thinking of getting the 255 cams, what would I expect from them? What were the noticeable differences you found after u did it? Also, about how much do the dealers charge for the upgrade? Thanks
The Fat Cat is a better match for your bike than the Boarzilla.
Check out Fuelmoto look at the TW 222 cams, I got them installed recently, pulled my SE 255 cams. Night and day difference, the TW cams give it way more get up and GO!
I'm going with the middle sound level baffle for my 13 Ultra Limited. I think its call perforated wrapped. I will be putting a Zippers max flow filter and power vision tune. No cams just yet. I like a loud exhaust.
The D&D with the standard baffle will def. be a good fit for you then if you like performance and loud! I have never had a quality issue or a complaint about any of the products coming from them. Have you decided which cut you planned on doing yet?
