2012 FLHX S/E Stage 4 103 kit
Old Nov 20, 2012 | 08:36 PM
GadgettR1's Avatar
GadgettR1
Default 2012 FLHX S/E Stage 4 103 kit
I have a 2012 FLHX and am planning on putting a S/E Stage 4 kit (p/n 92500011) in it over the winter along with the S/E Hi-Flo injectors and S/E cam bearings. The bike currently has a D&D Fat Cat exhaust, Big Sucker a/c and a Power Vision tuner. Is the factory oil pump on the 2012 103 sufficient or should I add the S/E Billet cam plate and hi-volume oil pump to the build?
Thanks,
Chip
Old Nov 20, 2012 | 09:44 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You might want to introduce yourself first on the newbie forum and then start to ask questions about what will and what won't work.
Old Nov 21, 2012 | 10:20 AM
Twillis's Avatar
Twillis
Strange, I always read a person's post with interest and ponder what the responses might be if I don't have anything to add. Some people, on the other hand, put the screws to someone just because they are new to the forum and don't have a lot of posts. I applaud the OP for jumping in feet first. Good Luck!
Old Nov 21, 2012 | 10:28 AM
GadgettR1's Avatar
GadgettR1
Ok if that's the "protocol" that's required here. I'll bounce to the "newbie forum" for introductions. But this is not my first time reading these forums and researching through them.
Old Nov 21, 2012 | 10:38 AM
0ldhippie's Avatar
0ldhippie
Personally I believe the S/E Billet cam plate and hi-volume oil pump are available to compensate for crank runout problems, unneeded in a street motor with a good crank. Before doing any motor work, check runout. If doing 100+ hp, weld the crank.
Old Nov 21, 2012 | 10:18 PM
GadgettR1's Avatar
GadgettR1
Thanks Oldhippie....
Magnut1
Jul 7, 2018 09:45 AM
FLHXKyle
Motorcycles For Sale
Sep 28, 2016 07:38 PM
watash
Welcome Area Only
13
Nov 23, 2014 10:52 PM
ga4boats
Feb 8, 2014 09:01 PM
MikeBarn
Jul 18, 2011 09:13 PM
