would this backrest bracket work ?
Old Nov 24, 2012 | 08:14 AM
DuraGlide's Avatar
DuraGlide
Originally Posted by riteway
Alot of guy sell their bike with the bracket still attached.I dont think these brackets are very expensive...$25-$30 new so that would be an EZ option.
+1 HD sells the bracket seperate. I bought one for my 2nd bike so I could swap the backrest between bikes.
Old Nov 24, 2012 | 11:27 PM
baust55's Avatar
baust55
cool thanks for all the info .
i have found a take off bracket for cost of shipping fairly certain it is correct bracket.
Old Nov 25, 2012 | 12:18 PM
baust55's Avatar
baust55
OK here is a photo of the bracket i am getting . It is from a 2010 ultra i think.
From several posts i have read it should bolt onto my 2008 FLHRC .
What do you guys think ? Will it work ?
Old Nov 25, 2012 | 12:22 PM
DTTJGlide's Avatar
DTTJGlide
Yes, it will work.
Old Dec 21, 2012 | 06:14 PM
baust55's Avatar
baust55
ya it worked perfect . i found when i went to put it on that the mounting stud plate was missing from my bike .The previous owner removed it.
I picked one up from HD for $3.29+ tax, the two plastic retaining washers were $3.50+tax.
Fishing the studplate up under the fender with out removing the rear wheel was a little complicated .
I put the bike on my sissor jack and let all of the air out of the tire i took the two ends of 5' of small hose fed it down threw the two holes in the fender i pushed the ends of the small plastic hose over the two threaded studs on the mounting plate and placed it between the fender and the tire (tight fit ) i pulled up on the hose and rotated the tire till the studs on the mounting plate came threw the holes in the fender . i grabbed one of the studs with some locking pliers .then put the plastic retaining washers on . then bolted up the backrest mounting braket to the studs on the studplate.
Looks good .comfey THRIFTY !
Ultra_RB
Jul 1, 2018 09:56 AM
ges32748
Mar 5, 2017 02:32 PM
AR4CE
May 5, 2015 07:46 AM
baust55
Nov 23, 2012 12:19 PM
bowhunter7532
Aug 8, 2008 07:12 PM
