9" LED Flexible thread lights on 2012 Street Glide
Old Nov 24, 2012 | 09:18 AM
snookie66's Avatar
snookie66
Default 9" LED Flexible thread lights on 2012 Street Glide
I'm looking at installing these 9" LED's on my 2012 Street Glide on the gap filler between the bags and the fender,running them vertically. I would like to tie them into the brake and running lights. What's the best way to accomplish this? Any ideas greatly appreciated...
Thanks
http://www.ebay.com/itm/RED-9-LED-FL...item2c60020958
Old Nov 24, 2012 | 10:42 AM
mfortkamp's Avatar
mfortkamp
I don't think you can because you need different brightness for the running lights than the turn/brake lights.
Old Nov 24, 2012 | 11:02 AM
HD HERB's Avatar
HD HERB
i ve seen them used on cars as brake lights never parking lights
Old Nov 24, 2012 | 11:12 AM
Bobber Jake's Avatar
Bobber Jake
You can use them so they just light up when you hit the brakes. You have two options, you can splice the brake wire and run them off that or you can go to local hd shop and buy an accessiory plug (cost like $10) and there is a wire that is for the brakes.
Old Nov 24, 2012 | 11:46 AM
coujac's Avatar
coujac
I did this but installed them under my tour pak. I tied them into the brake light. It was really easy and gives off a great amount of extra brake lighting. Since i have a detachable tour pak I purchased a deutsch connector to disconnect them.
BuffaloBill
Feb 3, 2014 10:02 AM
louisianaSVT2001
May 1, 2013 04:22 PM
Rhino //
Jul 3, 2011 06:31 PM
dlrshort
Sep 3, 2008 03:08 PM
jhogan20
Dec 3, 2007 08:05 PM
