Tire Mileage: A Tangle of Factors
Old Nov 26, 2012 | 08:49 AM
edpnjax's Avatar
edpnjax
I'm going on 14,000 on the original set on my FLHTCU and they still look great. No cracks, no cupping, no excessive wear. I don't baby the bike, but I don't hot rod it either. I do ride it alot on the hiway and up into the mountains in TN and NC, so it sees alot of hard cornering.
All I do is keep em aired up regularly. I run ~40 in the rear and ~38 in the front.
Old Nov 26, 2012 | 08:53 AM
lionsm13's Avatar
lionsm13
8 k for the rear, stock Dunlop.
Old Nov 26, 2012 | 08:59 AM
SkipCarey's Avatar
SkipCarey
12k rear 15 front cupped bad oem dunlops
Old Nov 26, 2012 | 09:05 AM
GSHOG's Avatar
GSHOG
I have an '09 Ultra Classic and at nearly 60K miles just put on the fourth rear tire. Have had three on the front. These have all been the stock Dunlops.
Old Nov 26, 2012 | 09:15 AM
dan conner's Avatar
dan conner
tires and oil changes...gotta spend our money on something. at that rate, you are talking a new tire every oil change.
you guys go on ahead and i will catch up later!
Old Nov 26, 2012 | 09:20 AM
Leftcoaster's Avatar
Leftcoaster
'95 EGC: front - 25-20K miles, rear - 5-6K miles
'06 SG: front - 20K miles, rear - 9-10K miles
" I can't drive 55!"
Old Nov 26, 2012 | 12:31 PM
Glockmeister's Avatar
Glockmeister
Forgot to add that I will be pulling a trailer on long trips in the summers after this season, so I expect my mileage to change, just hope I don't cut it down to what some guys are getting.
Old Nov 26, 2012 | 02:11 PM
The Old Man's Avatar
The Old Man
I have an 08 EGC. Basicly stock. I am 64 years old and do alot of fast starts away from lights. I commute daily to work 30 miles roundtrip down into the 20 deg. range. Cruise at 80 mph on the hiway and about the speed limit around town, maybe a little higher. I get about 13k on the rear and 18 to 20 on the front. I try to watch my tire pressures etc. Cruising around town I ride in what ever gear gives me the speed limit+ at 2300 to 2400 rpm. What I have notices that rides in that area of the country with winter and frost issues seem to get tires worn out faster. Roads up here have very rough surfaces and grindings to prepare for new asphalt. So I thing road conditions may be the answer that your look for. Heat from down south can have an effect also. JMHO
Old Nov 26, 2012 | 02:26 PM
Haywire's Avatar
Haywire
06 Ultra Classic and I weigh in at 230 get 7 to 8k on stock Dunlops. Going to try the Michelin Commander ll next.
Old Nov 26, 2012 | 08:38 PM
Brobrian's Avatar
Brobrian
Red face
Well, looks like riding style may be the big factor here. Of those who have Ultras my mileage is the worst. Though, unless I missed it, all were shoed with the wider tire.
While I do ride a Metzler ME 880, which some say is a softer stickier rubber, most are getting nearly twice the mileage I get.
For those looking in to find their own data. Mine is that I've ridden a great variety of miles, I rode across the US and back a couple years ago, ride with a club of sport touring riders in the twisties on a regular basis, and commute through town to work every day. My tire mileage hasn't really varied that much among the styles. If brake wear is another indicator of how hard we are on tires, I'm guilty there too. I change pads at every other tire change or about 8k and it's nearly metal on metal each time. As I mentioned at the beginning, I've used the stock Dunlops a few times and can't say the mileage was any different than on the Metzlers.
Sadly, the finger seems to be pointing back at me for my lousy tire mileage. I know I'll never change, however, so I just need to pony up, and shut up.
Attached Thumbnails Tire Mileage: A Tangle of Factors-tombstone.jpg
