Angled valve stems
Old Nov 26, 2012 | 08:46 AM
Chunker's Avatar
Chunker
Default Angled valve stems
This has been discussed before, the difficulty and crappy design HD uses in the touring wheels. Going to replace the tires on the 2011 FLHTK with stock wheels in the next month. When I replaced the 1st rear, I put on an angled valve stem, actually dealer installed it, I got from Dennis Kirk. About a 30 degree and about a 7mm stem diameter. While it's better, it is still difficult to check and add air. It has held up well, solid on the wheel, and does not leak.
I have looked at the "motorcycle anchor" product, 82 degree but the site doesn't give the diameter. DK now lists a K&L angles, 90 degree stems that says a 8.4mm diameter stems. From the pictures on-line, they do not apear to be billet. I also can not find who makes them so I suspect they are chinese crap.
Does anyone have any actual information on the K&L stems, and/or is there a source for the motorcycle anchor stems other than order direct.
Old Nov 26, 2012 | 09:32 AM
Leftcoaster's Avatar
Leftcoaster
Kurveygirl has what you want as does Jake Wilson - go to their websites.
Old Nov 26, 2012 | 09:52 AM
Chunker's Avatar
Chunker
Actually several places carry the K&L 90 degree ones. DK, JW, Motorcycle Superstore, J&P, etc. I was hoping someone had used them and had a report.
I was not able to find the "motorcycle anchor" product at any of the other vendors yet.
http://motorcycleanchor.com/
Old Nov 26, 2012 | 10:09 PM
ReidRik_Von's Avatar
ReidRik_Von
I have been really happy with the product. Rear one will go on when I replace the back tire this spring.
Old Nov 26, 2012 | 10:29 PM
MichiganRider's Avatar
MichiganRider
I was kicking around ordering a set tonight. But the link doesn't seem to work?
Old Nov 27, 2012 | 04:54 AM
flhrbill's Avatar
flhrbill
I will be replacing the stock HD Dunlops with the Dunlop American Elite this winter. No sense in keeping the original valve stems. Very interested in seeing what other stems people are using.
Old Nov 27, 2012 | 08:15 AM
Chunker's Avatar
Chunker
I just tried the link and it connected. Maybe they were "at lunch".
EDIT: Here's another page too.
http://www.motorcycleanchor.com/tire_valves/index.htm
Old Nov 27, 2012 | 09:31 AM
jjnoble's Avatar
jjnoble
you want the 10 or 11mm @ as close to 90 degrees as you can get. 30 degrees is a waste of time and money.
Old Nov 27, 2012 | 10:27 AM
Leftcoaster
Dude....what's to report? Ya' put 'em on and live happily ever after.
Guess that's my 'report'.
Old Nov 27, 2012 | 11:01 AM
2black1s's Avatar
2black1s
Personally I have no issue with the stock valve stems. Are they a little tight to get to - yes, but not so much to require a different stem. I use a conventional air chuck (approx 70 deg), and an AccuGage gauge with a 90 deg fitting. No problems. You just need the right tools. The wheels I'm talking about are the 28-spoke.
