oil usage
Old Nov 30, 2012 | 03:58 PM
hardheaded's Avatar
hardheaded
Default oil usage
2012 streetglide 2800 miles on it,just used 4oz. of oil in 900 miles.what do you all think?
Old Nov 30, 2012 | 04:00 PM
Keithhu's Avatar
Keithhu
1/8 quart while breaking it in? Ride it...
Old Nov 30, 2012 | 04:05 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Continue observations...
Old Nov 30, 2012 | 04:25 PM
mrfuji's Avatar
mrfuji
Default oil usage
hi.ring have to settle on new engine.what type of breaking-engine.you done.high rpm.than compression or just low rpm .mrfuji
Old Nov 30, 2012 | 04:38 PM
2black1s's Avatar
2black1s
4 ozs. in 900 miles? That translates to less than a quart over the change interval (5,000 miles). I wouldn't lose sleep over it.
Old Nov 30, 2012 | 06:20 PM
69cj's Avatar
69cj
Actually it comes out to 22.2 oz. Ride it. Will probably get better with miles but if it doesn't still acceptable for an air cooled engine in my op. if it doesn't get any worse.
Old Nov 30, 2012 | 06:37 PM
kennygsuperglide's Avatar
kennygsuperglide
Maybe I'm completely off target but from what I've learned about HD's is that they all lose a little oil out the breather. Once it gets a little below full on the dip stick it should stop.
Old Nov 30, 2012 | 06:46 PM
drukanfu's Avatar
drukanfu
4 oz. is just enough to wet the inside of your oil filter. Especially during the break in period, that is very good.
Old Nov 30, 2012 | 07:21 PM
Delta's Avatar
Delta
I gotta ask, how do you know it used 4oz? Did you drain it completely?
Old Nov 30, 2012 | 08:43 PM
2black1s's Avatar
2black1s
I agree with the general idea behind your question which to me is how do you accurately measure 4 ozs. of oil in oil pan. While I'm sure you can argue the absolute accuracy, there are ways to do it. No need to drain it completely.
One example I can think of is if you know where the oil is on the stick before, and you fill it to the same level after, and measure the amount you added, you'd have the answer.
