Torque wrench set
Old Dec 8, 2012 | 11:30 PM
Wanna Ride's Avatar
Wanna Ride
Originally Posted by cdemarse
I have a snap on and 2 craftsman. The snap on is nice but I use and have had zero issues with the craftsman. I suggest the craftsman. Think they are around $75.
I've got a Proto 1/2" that goes to about 200ft/lbs, and a couple 3/8" Craftsman that cover from about 100 in/lbs to 100 ft/lbs. Paid about $175 for the Proto nearly 15 years ago, and the most recent Craftsman on sale this past black Friday, for $39. Never had any problems with any of them. I think if you don't beat on them, don't drop them, and take relatively basic good care of them. pretty much any brand name one will be reliable.
Old Dec 8, 2012 | 11:34 PM
FXDXTSport's Avatar
FXDXTSport
I use this
Amazon Amazon
I use I bought it to calibrate the torque wrench (old craftsman) that I already own but ended up using this one all the time. It does both inch and foot pounds. Need some adapters for 3/8 and 1/4 inch drive though but cheaper than buying seperate wrenchs in each size.
Old Dec 9, 2012 | 12:07 AM
robo74's Avatar
robo74
Purchased the 1/2 and 3/8 and harbor freight, still need to get the 1/4. Had the two I have tested at the Aircraft facility I work in. The inspector who did the QA on them said they tested pretty accurate. For the home use I have, its a no brainer for me... no issues and worth the low cost.
I use my own tools to fix some stuff myself, both auto and cycle. I do not make money with my tools, so I have to make good budget purchases.
Just my .02
Old Dec 9, 2012 | 01:00 AM
Chunker's Avatar
Chunker
Originally Posted by HarleyGTP
Usually anything requiring a 1/2" drive torque wrench is torqued "***** tight".
Using torque-spec is more important with the smaller fasteners, 3/8" drive will be good enough for anything you need torqued in ft/lbs, and the 1/4" drive will be useful for smaller fasteners in the in/lbs range.
Yes that answer. I only use my 1/2" torque for wheel lug nuts. The 1/4 gets the most use so far, derby cover, oil drain plugs, etc. Just make sure when the torque spec is in inch pounds, that is what you do, not foot pounds. It does make a difference.
Old Dec 9, 2012 | 01:28 AM
bklynbob's Avatar
bklynbob
I'm sure a less expensive wrench will " work well", but accuracy can be + - 10%. Also they need to be re-calibrated/inspected at least every other year if you only use it a few times a yr.
Old Dec 9, 2012 | 05:03 AM
Jrsess's Avatar
Jrsess
Another vote for Craftsmen, especially when there on sale.
Old Dec 9, 2012 | 05:18 AM
Glockmeister's Avatar
Glockmeister
HF till I win the lottery.
Old Dec 9, 2012 | 06:01 AM
Gearhead3's Avatar
Gearhead3
Another vote for Harbor Freight. I can't find the article right now, but it was either Hot Rod or Car Craft that tested a slew of Tq. wrenches and the HF wrench tested well within the specified parameters. For the limited useage and dollars spent they can't be beat. (well, I'm sure they could, but you'd have to try awful damned hard!) LOL
Old Dec 9, 2012 | 12:49 PM
Duke 07's Avatar
Duke 07
I picked up the small and medium TQ wrench's from sears on black friday foe 39 a piece. They are normally 80. Haven't used them yet but they seem lie good quaity. I'm an aircraft mechanic and we pretty much have all Snap On at work but can't justify the cost for them at home when I only use them on a rare occasion. If I need I can bring one home but really bought these for convenience.
Old Dec 9, 2012 | 01:21 PM
SamStone's Avatar
SamStone
I've used Harbor Freight for years. Never stripped or lost anything.
