Front tire removal
Old Dec 10, 2012 | 10:14 AM
Jswerve's Avatar
Jswerve
Default Front tire removal
2012 flhxse3 can you do this without taking off calipers and simply raising the bike high on a lift and dropping the wheel out of the calipers and out? Never taken it off just wondering?
Old Dec 10, 2012 | 10:19 AM
glide2meetu's Avatar
glide2meetu
Yes the rotor will come off with the wheel and you should be able to do this with the bike lifted.
Old Dec 10, 2012 | 10:22 AM
hardheaded's Avatar
hardheaded
no, you need to take calipers off first.
Jswerve's Avatar
Jswerve
Scratching my head, which is it???
Old Dec 10, 2012 | 10:25 AM
131tman's Avatar
131tman
That's plain bad advice.
Jswerve's Avatar
Jswerve
Explain...
Old Dec 10, 2012 | 10:28 AM
klwheat's Avatar
klwheat
5th Gear
I'm curious about this too. Also, what are you using to lift the front?
Old Dec 10, 2012 | 10:35 AM
fat daddy's Avatar
fat daddy
The easy way is just take the caliper loose and tie up to the engine guard. You probably could leave it on and drop the wheel but when you put the wheel back on it might be a pita.besides taking caliper off is soooo easy
Old Dec 10, 2012 | 10:37 AM
Jswerve's Avatar
Jswerve
Why can't you simply push the caliper piston back in to open up the pads and slide the rotors back in? Taking it off is easy but I am determining whether it's a necessity not whether it's easy.
Old Dec 10, 2012 | 10:43 AM
131tman's Avatar
131tman
Originally Posted by Jswerve
Explain...
Remove calipers...period!
