Is it possible to put a 2007 SG tank on a 1998 Ultra Classic? I was wondering because I found a good deal on one but want to make sure it works. The part that worries me is the fuel pumps..I did a search and came up notta.. hopefully the experts will chime in.
No it will not work, you are limited to a FI tank up to 01 & some early 02 tanks. You need to find one that has 2 outlets on the tank for your FI pump.
Sorry I'm a newbie but...
My motor is a S&S V80 with a super E carb. Does that mean I will still have a FI pump?
If that's a stupid question please don't yell at me... I'm TOTALLY new to the HD world so bare with me. Thanks!
Okay, thanks! I'll check for the adapters and then look to see what all it takes to install all that stuff.
It might just be easier to buy the tank that will work for me....
That being said, what tanks will work then? Should I just stick with a stock 98 ultra classic tank or will something take it's place as a direct fit? I'm assuming they will fit if they are without FI, but idk for sure.
