First highway trip today... pinging!
Old Dec 28, 2012 | 08:09 AM
jjnoble's Avatar
jjnoble
It only happens in 6th gear so it is probably not the plugs or wires, air flow or anything like that. Although you should check those things to be sure. The problem is probably either the timing or the AFR. Retard the timing a degree or two in that RPM range so it will not burn so hot. Pinging is caused by your engine burning so hot the fuel ignites before the spark. I don't know much about an 07, but you will probably need a tuner in order to adjust the AFR and timing.
Added: I am a big believer in the knightrider Xied's. They are not a cure all but they may be all you need.
Old Dec 28, 2012 | 09:26 AM
mikelikesbikes's Avatar
mikelikesbikes
Originally Posted by TUCCI
If you look at the 'RPM to gear ratio' on the above chart youll notice the RPMs will not be very different from 5th gear at 70-75 than 6th. But that difference will be enough to minimize or eliminate the ping. My suggestion is you do as I do and not use 6th gear unless your going to be cruising at 80+ for sustained intervals. This and retarding my timing has minimized carbon buildup which made pinging prevalent at the RPM ranges your describing.
TUCCI, where can a person download this chart from ?
Old Dec 28, 2012 | 09:46 AM
t. sawyer's Avatar
t. sawyer
all it took for my 07 street glide was a steady diet of "sea foam" which cleaned carbon from the combustion chamber. It's possible to see improvements with the very first use.
but give it 3 tank fulls of gas to work. I like this stuff alot. I use it in everything tha has an engine. good luck.
Kroozeabout.
Old Dec 29, 2012 | 03:22 PM
jeveretts's Avatar
jeveretts
Well... working on the bike, I found a power commander under a side panel. Removed it, now pinging is gone. Every slight issue I had with the bike is gone. Runs like brand new now. Go figure.
Old Dec 29, 2012 | 04:13 PM
Jswerve's Avatar
Jswerve
If you have the power commander and it's paid for wouldn't you want to have the bike tuned???
Old Dec 29, 2012 | 04:33 PM
griffon's Avatar
griffon
Before you try all the expensive tuning and mods try a can of Seafoam in the gas tank. About $6-$7. Run the scooter until the tank is almost empty.
This may eliminate the carbon that is causing the pre-ignition.
griff
Old Dec 30, 2012 | 05:01 PM
jeveretts's Avatar
jeveretts
Nah, if it is running good, and the mileage is good, I got better things to do with the money.
Old Dec 30, 2012 | 06:51 PM
aviscomi's Avatar
aviscomi
Go to the Power Commander website and download the appropiate map for the A/C & Pipes you have install on the bike.
Old Dec 30, 2012 | 07:18 PM
Jswerve's Avatar
Jswerve
Ok throw it away then....
Old Dec 30, 2012 | 08:50 PM
mgmmgm's Avatar
mgmmgm
Trade your power commander in on a PowerVision tuner through Fuelmoto, if they still have their special going on.
