Big bore kit install
Old Jan 4, 2013 | 09:37 AM
sgod1100's Avatar
sgod1100
Originally Posted by kdodd
I recently had a big bore kit installed, saw some of what I thought was a oil leak coming from the base of the rocker boxes. Engine guy says it is the lube he used to torque the head bolts. Not had a lot of time to ride since the build. Put on around 80 miles. Cleaned it up a couple of times and still seeping a little. For you pros, is this normal? Should I give it a few more miles, or take it back to get it checked.
If it's seeping after you wiped it then it is still leaking....take it back and get it fixed.
Old Jan 4, 2013 | 11:00 AM
Joker65's Avatar
Joker65
Originally Posted by leon anthony
what little lube it takes to lube the theards of the head bolts should NOT be leaking out
Well, not only are the threads lubed, but also the flanges of the head bolts.
Sometimes, I have seen that get a bit messy... and yes, me too. LOL
I'd agree with Stupid_Rope (I feel funny saying that!)... give it a little time and monitor it.
If it doesn't clear up, go see your Indy.
Or, there could be something totally catostrophic going on!!!
Old Jan 4, 2013 | 03:32 PM
Mike's Avatar
Mike
Well, it's not likely to be catastrophic, so waiting a few days or even a week or two won't hurt anything.
A leaky rocker box after a top end teardown is not uncommon. It would be very uncommon if it self-corrected.
artsbest
Milwaukee Eight (M8)
75
Jun 23, 2022 08:56 PM
magnum629c
Mar 30, 2014 10:50 PM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
Feb 27, 2012 07:08 AM
RidemyEVO
EVO
Jan 23, 2011 08:38 PM
mudrat_fat05
Feb 26, 2010 04:04 PM
