Power Vision with a Power Commaner V
Old Jan 11, 2013 | 10:24 AM
1sweetglide08's Avatar
1sweetglide08
Originally Posted by zwildman
Wow, excellent advice from everyone especially Jamie!
As much as I like the PV display and available information it sounds like I'll keep my PCV and ride on. I really can't fault the way the motor is running at all and even mileage is good, 45mpg or better, when I'm conservative with the throttle. Wide open runs and quick launches suck it back down to around ~41mpg but things are really fine.
Thanks all!
All said is true...The only advantage would be not have a piggyback tuner connected to you ECM. The PV will flash your ECM and you can put it away.
Old Jan 11, 2013 | 10:28 AM
Jswerve's Avatar
Jswerve
Well not the only advantage lol. There's the handlebar mount and display that allows you to connect real time data and make adjustments and the ability to store 6 maps to name a cpl.
Old Jan 11, 2013 | 10:45 AM
golfblues's Avatar
golfblues
Stay with what you have. It works, its simple and its paid for. If you didn't have auto tune it would be different.
Old Jan 11, 2013 | 07:03 PM
FAUVDOG's Avatar
FAUVDOG
Ok what about the guys that have pcv without auto tune and have the nb o2 sensors because they didnt by the 09 vh dresser duals but bought the dresser duals that have bungs for nb sensors is it worth it to get the pv?
Old Jan 11, 2013 | 07:15 PM
USAFANG67's Avatar
USAFANG67
I talked to a guy at a HD dealer who installs and tunes PCV and he said for the small amount of HP & Torque one would pick up that it's not worth going to the Power Vision.
Old Jan 11, 2013 | 07:37 PM
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
The Autotune doesn't do anything with the PV until you accept the values and re-flash your ECM. It simply collects data. With the PC V it continually monitors and adjusts fuel for optimum performance. Once you update the Autotune maps a few times and adjust the correction % to 5%, you're good to go. At least until you change something like exhaust, cams, etc.
loose_Change
Touring Parts
Jan 5, 2014 12:57 AM
toku58
Sep 11, 2013 10:22 AM
UT-rckr
May 27, 2013 08:50 AM
cbi1000
May 2, 2013 11:32 PM
Godeater
Mar 1, 2009 01:50 PM
