Speedo vs GPS
Old Jan 13, 2013 | 05:32 AM
grbrown's Avatar
grbrown
Cool
Originally Posted by A5Firearms
Is there anything that can be done to make it accurate?
No. The speedo is dependent on the rear wheel, except older bikes that may have a front wheel cable-drive speedo. When a rear tyre is new it has about 3/8" tread and is typically just over 25" in diameter. If we wear the tread down to zero, the diameter changes by 3%. The speedo is only accurate to between zero and 5%, so adding those together the scope for error with a speedo is quite a lot. 'Twas ever thus - blame gps for revealing the ugly truth!
If you want better accuracy, use a gps.
Old Jan 13, 2013 | 06:03 AM
rtmichael's Avatar
rtmichael
Thundermax allows the speedometer to be calibrated. Don't know about other tuners.
Old Jan 13, 2013 | 06:22 AM
vzts4q's Avatar
vzts4q
Several tuners can do this.
TTS and Powervision are 2
But be stay away from the plug in calibrators on any bike with a cruise control of 6th gear light unless you want to loose these functions I found this out the hard way with the Dakota Digital Electronic Speedometer Adjustment Module at the time I bought it they did not have the warning about it affecting the cruise. As noted at the bottom of this link.
http://www.dakotadigital.com/index.c...rod/prd238.htm
Old Jan 13, 2013 | 07:35 AM
Jinks's Avatar
Jinks
Originally Posted by K Melancon
On all vehicles (except police vehicles) the speedometer will show 2 mph faster.
That's about as inaccurate as you can get. I've owned two BMW cars that average 3 to 7 mph faster than true. One BMW motorcycle that was a consistant 7 mph fast, several Harley's that average 3 to 5 mph fast, & one Pontiac SUV that is dead accurate.
For the OP, there are a few add-on units that claim to adjust speedometers. Their accuracy is suspect. The ThunderMax Auto Tune I have in my FLTR has corrected that speedo. Power Vision will do the same. A really good tuner that will correct spedometer inaccuracy is a great thing.
Harley could do it, but won't. It's an algorithm in the CPU that interprets speed from the transmission. Correcting that algorithm corrects the signal to the speedo.
Old Jan 13, 2013 | 07:43 AM
djaudette's Avatar
djaudette
Mine is also about 4 mph faster then actual speed.
Old Jan 13, 2013 | 08:10 AM
K Melancon's Avatar
K Melancon
And I have had several trucks that were under at times, over at times, way over at times, and now dead accurate. How because I changed tire size from the factory size. Bigger the tire like big ole mud grips will put you way faster than what the speedometer is showing. When they had cables you could change the gear but I never did just learned how far off and lived with it. I now usually go just one size up and it will be accurate with my GPS. Remember this is with a new vehicle and new tires, tire inflated to proper pressure, with no worn componets for 2 mph off. If you dont believe me contact your vehicle manufacturer just like I did for a court case.
Old Jan 13, 2013 | 08:17 AM
PowerstrokeNC's Avatar
PowerstrokeNC
The wife and I went on a 200 mile ride today so I thought this would be a perfect time to try out the new GPS mount. While riding I looked down and compared my speedo verses the GPS and at 80mph on the speedo, my GPS was reading 75mph! I thought WOW that is pretty far off. Is this normal?
Yep, just checked mine yesterday had the same 5mph variable with the speedo over reading vs the GPS.
Old Jan 13, 2013 | 08:18 AM
PowerstrokeNC
If I remember correctly you can calibrate the speedo with a super tuner.
Old Jan 13, 2013 | 08:43 AM
ShoreRider's Avatar
ShoreRider
I've verified my speed against stationary radar and then compared to GPS reading. My speedo ('12 FLHX) is 2 mph faster than the radar and 3 mph faster than what GPS tells me. On my SUperGlide Custom, the speedo is 4 mph faster than radar and 3 faster than the same GPS. Go figure huh?
Old Jan 13, 2013 | 08:51 AM
hogcowboy's Avatar
hogcowboy
I actually don't mind it showing high. I go mainly by sound when cruising down the highway and when it purrs I'm doing about 72 according to speedo and that keeps me from getting tickets. 2500 rpms seems to get me the best fuel mileage and that's around 72mph. Works for me.
