Help on ABS Modulator Replace
Old Jan 15, 2013 | 09:16 PM
dowhat's Avatar
dowhat
Default Help on ABS Modulator Replace
Had mine replaced at dealer. Had no front brake pull. Before I go off and make myself look like a dumb *** I just need to make sure I'm not. All brake lines tie into this modulator.
Picked bike up in rain, put on trailer to take home. Ride to work, front works ok, bake seems like I don't have any. Ride back home with same feel. Open back master cylinder cover only to find no brake fluid. Check front, and it's also low. I was thinking maybe they should have bleed and check the fluids with the repair, but I've been wrong before, so any one with this knowledge please chime in. Thanks
Old Jan 16, 2013 | 06:34 AM
skratch's Avatar
skratch
i would say that you are not a dumb ***. they should have checked the fluids and topped them off (and bled them as well)
Old Jan 16, 2013 | 08:26 AM
grbrown's Avatar
grbrown
Unhappy
Yup. Back to the dealer and grasp the Service Manager gently by the throat.....
jwnusbaum
May 29, 2017 05:38 AM
Choopy
May 23, 2015 12:33 AM
Choopy
Apr 24, 2014 12:21 AM
rstekeur
Feb 16, 2014 02:19 PM
