Anyone have to drill out 6mm bolt from lower forks?
Old Jan 16, 2013 | 11:30 AM
Coastiejosh's Avatar
Coastiejosh
For now I will have to drill it out. I will look at getting some type of impact tool. Thank you guys for your help. I will drill it out after I remove the cap and drain the oil.
Old Jan 16, 2013 | 11:46 AM
rg_dave's Avatar
rg_dave
I used an air impact.
Old Jan 16, 2013 | 11:47 AM
rleggs's Avatar
rleggs
I've found that in most rounding hex slot screws you can go to a sightly larger torx bit and tap it into the hex and it will free it up for easy removal.
Old Jan 16, 2013 | 03:26 PM
pit1600's Avatar
pit1600
Hard but by hand. Have to change the screw after...
Old Jan 16, 2013 | 04:23 PM
hardheaded's Avatar
hardheaded
drill it out
Old Jan 16, 2013 | 04:30 PM
Uncle Larry's Avatar
Uncle Larry
http://www.harborfreight.com/impact-...ase-37530.html
Old Jan 16, 2013 | 04:36 PM
chamokie's Avatar
chamokie
Use a left hand drill bit, will help to remove stubborn screw
Old Jan 16, 2013 | 04:46 PM
run1fsr's Avatar
run1fsr
Originally Posted by Watchfuliz
Cheap hand impact with long allen 3/8" drive and a hammer before pulling the top cap works everytime for me. I have done 10 sets of forks this way without a problem.
I’m getting ready to start the same project. Did you break everything loose with forks mounted on the bike or with the parts sitting on your bench?
Old Jan 16, 2013 | 04:47 PM
slammed05fatty's Avatar
slammed05fatty
Mine did same thing, drilled it out. Pretty simple task
Old Jan 16, 2013 | 05:04 PM
malbanese45's Avatar
malbanese45
Drilled mine after it rounded out. The piece thats left behind comes out easily after the slider is removed.
