Cams and valvetrain life, stock Vs aftermarket?
Old Jan 22, 2013 | 06:33 AM
Notgrownup's Avatar
Notgrownup
At 50000 miles i took my stock cams out to replace with 26H and the stock looked like new...the ones i put in were used and looked like new also...I think if you go with a mild bolt in cam set you should have no issues with longevity.
Notgrownup's Avatar
Notgrownup
Originally Posted by satman
Here are pics of stock lifter rollers and cam lobes from a 2012 RGC 103 with 15,000 miles on it. Mobil one VTwin oil changed regularly. As you can see problems are not too far down the road with stock components. I put Andrews 57h cams in with a good used set of HD "B" lifters in it. One thing I noticed was that the stock cams in this 2012 HD are made of several parts welded together instead of one piece of quality steel. Previous stock HD cams from a 2000 Road King and 2006 Deluxe were the one piece design - I wonder how much money the MOCO saved from cheapening out on a vital engine component. BTW my crank runout was .006 - really sucks - the crank runout in my 2000 RK was .001 Slowly but surely my love of HD is reduced by this cost cutting BS
Those do look like ****...
Old Jan 22, 2013 | 08:36 AM
lionsm13's Avatar
lionsm13
Originally Posted by Molarman
I dont have a lot of experience yet. I just had cams installed in my 103 limited a few days ago. I went with the Fueling 525 cams. They seem to be a mild cam that would be easier on the engine. The little bit I have rode has shown me a huge improvement in power. Dyno at about 90HP and 103 Torque.
I went with the same cams for my 96."
The numbers look about the same all in all.
I wanted something that did not stress the valve train too much, but something that would give me a bit more punch.
It seems to be good so far.
MPG could be a bit better. Getting 33-36 depending on hard I throttle.
Runs great though.
Did a lot of reading on cams, had TW6-6's sold them as they come on too late and then 48H's as they're a lot like the 255's, but go out furher.
Sold em' both before installation.
Happy with the 525's for time time being.
It's a bagger..not a ninja. lolol.
Old Jan 22, 2013 | 08:57 AM
gregsdart's Avatar
gregsdart
Originally Posted by grbrown
Are you building a race Harley, or a road one? If you are building a road motor I can't see any suitable cam giving problems.
I was/am looking for feedback from guys that put a lot of miles on heavy touring bikes with aftermarket cams. I ride a Limited, would never go beyond a cam somewhere between a 255 and as an example a tw 555, and more than likely a cam very similar to a tw 222. (as a possible upgrade from my current se255s)So to be specific , would the average life drop 50 percent? 25 percent? Not at all? Are there proven components that are better than stock that will keep the same reliability as stock or improve it?
The problem is there are MANY answers to these questions, because there are many cams to choose from. Maybe cam company A feels that they need to keep reliability above say 75,000 miles, roughly. Cam company B might figure that 50,000 average miles is OK for the same type of cam, so they build in a little more ramp speed to up the torque and widen it a bit. Company C figures that they can sell very aggressive torque cams, and maybe 30,000 miles is the average life of the valve train with their cams.
So I hope there will be a ton of feedback from guys installing various cams, and how many miles they have ridden with them. After a LOT of feedback, patterns will form!
Old Jan 22, 2013 | 09:13 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Anything mechanical or electrical can fail at any time for many reasons. In my opinion, what your asking for is almost impossible because there are to many factors that can affect longevity. Pick the cam that best suits your riding habits, install it yourself (if you have the knowledge & tools) or have it installed by a trusted indy and ride on...........
Old Jan 22, 2013 | 09:15 AM
fwb35's Avatar
fwb35
SE 204 cams, 48k, no problems
Old Jan 22, 2013 | 09:40 AM
taconite's Avatar
taconite
I have SE-264 cams and just looked at them last fall after 15K miles they look like new. No signs of spalling like in the photos. These are hard cams and I know I most likely wont get 75K out of them. I think springs play a huge role in all of this! My valves / lifters are what some would say are "loud". With those types of failures you have in the photos it really comes down to load and lubrication. You lost the hydrodynamic lubrication barrier needed to separate the two surfaces. Because of the amount of oil in there I doubt it was quantity but more quality of the oil. A higher base oil viscosity and EP package might be needed. If base oil viscosity gets to low due to heat or breakdown from age, the oil will not maintain a sufficient film thickness and barrier to separate the two sliding surfaces. As load and temp increases in mineral oils the ability of the oil to perform it's function decreases. Synthetic oils with additive packages are sometimes an easy solution to this. They often have extreme pressure and other additive packages to help deal with extreme operating conditions like load and temp.
Old Jan 22, 2013 | 09:58 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I decided to go with the SE255 as part of my performance upgrade after talking with my dealer about your very same question. They told me they have had zero problems with that cam, and it would not shorten the life of the motor in any way. They said, in fact if not for the EPA, all 103's would probably leave the factory that way.
My setup could not fit my riding style any better. I wanted more torque at lower RPM's for two up, twisties, and hills without always giving up on 6 gear.
It's all good, 15K with Mobil 1 V-Twin 20w50, no problems...
Old Jan 22, 2013 | 10:33 PM
gregsdart's Avatar
gregsdart
I have already put in 255s, and am very well aware of potential problems with any machine at any time. but there are trends that show themselves over time. So far there are responses with a cam change, everything looks good at 90,000 miles, etc. That is the type of info I am looking for. Before I go ahead and put in a better cam, like for instance the tw222, It would be great to hear how cams from that maker hold up over the long haul.
Old Jan 22, 2013 | 10:39 PM
gregsdart's Avatar
gregsdart
Good example of feedback! thanks!!
