Interesting cam question
Old Jan 24, 2013 | 08:25 PM
lip's Avatar
lip
Default Interesting cam question
Have an 01 electra glide. Need to replace cam tensioners. Would like to upgrade cams while doing it but cannot afford new hydraulic set up right now. Can i upgrade cams using stock set up? I know i will at least need adjustable push rods
Old Jan 24, 2013 | 08:27 PM
snip0721's Avatar
snip0721
its been done thousands of times. steve
Old Jan 24, 2013 | 09:01 PM
bigdog1949's Avatar
bigdog1949
Default tenisoner repair 88
best bet with an 88,leave your cams,if you want power buy a busa,if you want a smooth engine and mileage buy a honda,,on utube there is a video on a tool that removes the tenisoners without removeing the cams,it works i made one !!,pull your pushrods from the top,maybe gaskets and seals 50 bucks your done,the engine was designed by the flintstones,what more can i say
Old Jan 24, 2013 | 11:03 PM
jmn1960's Avatar
jmn1960
Talking
gotta link for this tool??? sure would like to see it,
Old Jan 24, 2013 | 11:16 PM
INDEPENDENT_1's Avatar
INDEPENDENT_1
Yes, go with an Andrews 26 and you'll have more power and room to do a big bore later and not have to replace the cams again. If you're going to use the stock style tensioners, go with the cyco tensioners. They appear to be made of better material than the stock and last longer.
Old Jan 25, 2013 | 05:17 AM
ShadowMonster's Avatar
ShadowMonster
Actually on a red neck you tube video
Old Jan 26, 2013 | 10:08 AM
jmn1960's Avatar
jmn1960
who can make me one of these??? and how much, no good at building sh*t
Old Jan 26, 2013 | 12:13 PM
chinookman's Avatar
chinookman
That is completely red neck!!! I guess it gets the job done though.
Paul32730
Exhaust System Topics
Apr 29, 2026 11:37 AM
GibsonSG
Sep 13, 2017 12:48 AM
trnewman
Apr 25, 2013 07:31 PM
BackRoader
Feb 13, 2011 07:23 AM
wiseguyups
Jan 11, 2010 11:02 PM
