roadglide upgrades
Old Jan 27, 2013 | 01:19 PM
waynemags's Avatar
waynemags
Default roadglide upgrades
2012 roadglide. 2into1 bassanis, se heavy breather, se race tuner. looking at cam choices. want good tourque from start to top. ride mostly highway and cruise around 125kms hr. like to wake this 103 up. any suggestions on cams? not looking at headwork for a while so would appreciate cam opinions.
Old Jan 27, 2013 | 01:32 PM
DTTJGlide's Avatar
DTTJGlide
All cams are a compromise, you can't have it all unless you have variable valve timing, that's why the new cars can have as much lo w end tq & still achieve the hp #s they have now. If you want a cam that will work well when you decide to port the heads you'll have to give up a little tq down low now or a little hp up high later. With that said my recommendation would be Andrews 54s or 57s, or Woods 555s, possibly with a 4* cam gear to give you a little more tq until you do the heads.
Old Jan 27, 2013 | 01:50 PM
0ldhippie's Avatar
0ldhippie
But I'm not a fan of the 4* gear. Go for less cam instead. the 57 or 555 are great choices in a stage 1 103 imho.
Old Jan 27, 2013 | 03:30 PM
NorCalFBLO's Avatar
NorCalFBLO
I just went through this with my 2013 FLTRX. In my research what kept coming up was:
Woods 222
TMan 555TQ
Cycle Rama 575
I went with the Cycle Rama 575. Like you the only engine modifications I had was a 2:1 Dragula, SE Heavy Breather A/C, and TTS.
Old Jan 27, 2013 | 03:35 PM
smitty901's Avatar
smitty901
SE 255 made for your ride by those that built it they work well none of the issue with tuning. Bike retain more value.
RG and RGU rock .
Old Jan 27, 2013 | 04:54 PM
DTTJGlide's Avatar
DTTJGlide
RG and RGU rock .
The 255s were made for the EPA, some guys love them, most that have tried something else not so much. The biggest thing is you need to decide what your end goal is. What works best at a stage 2 isn't going to be the best at stage 4. If you can swing it, it's best & cheapest to do the build only once, since a lot of the labor costs overlap. I know that's not possible for everybody, but at least have an end goal in mind when you start.
Old Jan 27, 2013 | 09:01 PM
equandt's Avatar
equandt
I've got my eye on the TW-222. Looks like a TQ monster down low and runs out nicely on top. It also looks like you can add heads to it if you need more HP on the top end.
Good luck.
wfohog
Engine Mechanical Topics
Oct 4, 2016 10:08 PM
fatboy1729
May 15, 2012 10:23 AM
MCSarge
Exhaust System Topics
Aug 24, 2010 06:26 AM
hrchdog
18
Dec 18, 2009 05:35 PM
DCRANER
May 9, 2006 12:59 PM
