Are you trying to justify this to yourself or your wife? If yourself - no, it's not needed. If you want it & are trying to convince your wife - absolutely, it's an essential piece of equipment.
there's balance required on any lift. That one removes the front/rear balance as long as the wheels aren't lifted, but it's still a bike, it can easily tip to either side.
This here is a guy that knows how to be married. No tellin how much money has been spent on "essential equipment" for my bike over the years.
I would think a jack would get in the way more than help, a true table lift would be cats ***. My buddy has one, and has a scissor block jack he puts under the frame to remove a wheel or for additional stability
Bingo !! ... What he said ... Use care and caution WHENEVER your scooter is off the ground.
"I probably need to buy my parts before the races start, while is still have money....."
Haha that's funny!!!!! So you really think your still gonna have money after leaving the HD dealer. I'm not sure which does a better job lightening the wallet, the track or the dealer.
Yes there is, everything usually follows the basic laws of physics however, I own both a center stand hydrauilic lift and an 8' pneumatic lift and my point was balance is critical on the center lift, not on the other.
Remember to clean the pipes with Windex to remove your hand and finger prints before starting your bike or they will be there for life.
Also if you are installing headers pipes and muffers have everything lines up before tighting the bolts, work from the heads back when tighting.
